Pc-Mobile Frequent Visitor
Joined: 26/10/2002 10:38:36 Posts: 789 Location: Hong Kong
Posted: Sun Sep 14, 2003 8:04 am Post subject: Connecting PPC / Road Angel / Serial GPS |
WE received enquiries from time to time about connecting Raod Angel to a PDA.
Since we do not know anything about Road Angel, our answer was always to ask the GPS manufacturer.
Though I do not have one on hand, I have done some study and the concludion is that Road Angel is the same as any other serial GPS for connection purpose.
It has a standard serial output (female DB9) to connect to a PC.
To connect to a PDA, you can use a male>male 9-pin null modem adapter (DB9N) to connect to the serial sync cable of your PDA (Visor/Clie T/NR/NX excluded).
We have serveral options supporting over 90% of recent PPC and Palm devices.
(These also apply to any other standard** serial GPS devices with DB9 serial interface)
Serial/modem/GPS interface (null modem adapter built in):
Ipaq 36/37xx - PQSM
Jornada 54/56x - PHJSM
XDA - PXSM
Palm M5xx/Tungsten - P50SM
Sony Clie S/N series - PSSM
Sony Clie newer models - PSTGS
These connect directly to serial GPS.
But these are all short cables (20-30cm) designed to connect to a serial cable, you will need a serial extension cable (9-pin male>female) for practical purpose.
GPS interface for PDA + serial GPS interface (G9XPM)
You need the serial GPS interface G9XPM (http://pc-mobile.net/g9xpm.htm)
PLUS the GPS interface of your PDA:
Ipaq 36/37xx - GQ36
Ipaq 38/39/54xx - GQ38
Casio E11x/12x/EM500 - GCA1
Jornada 54/56x - GHJ5
XDA- GXDA
Palm M5xx/Tungsten - GP50
Sony Clie S/N series - GSN7
Sony Clie T/NR/NX/SL/SJ/NX - GST6
Visor D/L, Prism - GHSV
Axim - GAX5
Fujitsu LOOX - GFLX
Viewsonic V35/Mio - GV35
These work out to be more expensive but more flexible
GPS combo interface with power input.
These work the same way as above but with power input option
(so you need G9XPM plus one of the follow):
iPaq 38/39/54xx - GQ38p
XDA- GXDAP
Palm M5xx/Tungsten - GP50p
Sony Clie S/N series - GSN7p
Sony Clie T/NR/NX/SL/SJ/NX - GST6p
Viewsonic V35/Mio - GV35p
And appropriate power source (CKUC/CPUC/PB4A) if needed.
Others do not need a combo interface because there is separate power input
**Standard serial GPS means GPS with standard NMEA output AND work with only RX/TX/GND connections.
Some serial GPS (e.g. Delorme, Rand McNally) require DTR connection or output different format so are not classified as standard (as far as we are concerned) so these will not work. You have to consult your GPS manufacturer if in doubt. _________________ Pc-Mobile
http://pc-mobile.net/gps.htm |
jinjin Occasional Visitor
Joined: 11/04/2003 11:33:46 Posts: 1 Location: United Kingdom
How much is the following cable cost?
Axim - GAX5
Regards! _________________ JIN |
GAX5 does not work on its own.
Please see information (prices and many other things) on our web site.
Dave Frequent Visitor
Jin, what GPS are you looking to hook up to the Axim X5 ? |
I bought a PQSM from yourselves, and my Road Angel still wont "talk" to ym Ipaq 3630..
Any ideas? |
Any ideas?
It is very likely because of incorrectly configuration of Ipaq/GPS/software. Any one would have caused it. |
