Pocket GPS World :: View topic - Garmin DriveSmart 65 MT-D Verbal speed camera warning.
INTRANET
PostPosted: Fri Oct 01, 2021 6:26 am    Post subject: Garmin DriveSmart 65 MT-D Verbal speed camera warning. Reply with quote
Hello, I'm new here. I bought Garmin DriveSmart 65 MT-D but unfortunately they don't have verbal speed camera warning. But from this forum I read it with some app you can deploy this feature. But I have some questions. What will happen with Cyclops speed camera? Is it possible just deploy audio files which works with Cyclops speed camera. Secondly I don't know maybe it is not possible with DriveSmart 65 device.
PostPosted: Fri Oct 01, 2021 6:29 am    Post subject: Reply with quote
Cyclops is a .GPI download and you have no access to change this.
If you want verbal warnings then you'll need the database from here and follow this tutorial for both sound and vision :
https://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=97158
Satnav:
Car Average MPG :
INTRANET
PostPosted: Fri Oct 01, 2021 8:08 am    Post subject: Reply with quote
Thanks. One more question Interface and audio is set Latvian language. If I want verbal warning should I need to change audio to english or is ok to leave it as I set? And how often speed cameras get update?
PostPosted: Fri Oct 01, 2021 8:24 am    Post subject: Reply with quote
Ah, I have no idea about the various languages.
I also don't know if we do a Latvian version. You'll need to check.
Satnav:
Car Average MPG :
dales
PostPosted: Fri Oct 01, 2021 9:35 am    Post subject: Reply with quote
The PGPSW speed camera database is updated once a week.
The language setting on the Garmin is for the routing information (eg In 200 yards turn left). Set that to your native language.
Whereas the available camera warnings are recorded in English, and play in English.
(It is possible to record your own warnings in your own language if you have some skills and equipment and patience).
INTRANET
PostPosted: Fri Oct 01, 2021 10:40 am    Post subject: Reply with quote
Thanks, for repley. This is what I hoped to hear. So I'll try later to get work with my device. Sorry for silly question. Will it warn driver if you even drive with lower speed?
PostPosted: Fri Oct 01, 2021 10:53 am    Post subject: Reply with quote
Probably not if you use the Garmin app
You need something like my CSV Converter that forces a mandatory warning regardless of speed.
Satnav:
Car Average MPG :
INTRANET
PostPosted: Fri Oct 01, 2021 11:17 am    Post subject: Reply with quote
You mean this thread: https://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=91951
So I'll try manage where to start, what software need, what need to download, what need to convert.
PostPosted: Fri Oct 01, 2021 11:56 am    Post subject: Reply with quote
That's the one.
One thing to note is that Garmin have given Cyclops the way to make the warnings directional.
Via POILoader we can only produce warnings that trigger from any direction.
Before you get too involved have a look at the SpeedtrapAlert thread.
That runs on your phone and is directional.
I use the Garmin DS61 for the visual alerts (speed icon via speed zoned) but have the Garmin volume at zero. Then STA produces the verbal warnings via the car system via bluetooth.
Satnav:
Car Average MPG :
INTRANET
PostPosted: Fri Oct 01, 2021 12:24 pm    Post subject: Reply with quote
Thanks for info. Unfortunately Volvo S60 2011 doesn't love Samsung Galaxy Note 20 Ultra (Snapdragon). Very often its works like 5sec goes audio then for 1sec quiet. It is so annoying and I remove device from car system. This is one of reasons why I bought Sat Nav device (I don't want to use phone as navigation.)
PostPosted: Fri Oct 01, 2021 1:29 pm    Post subject: Reply with quote
STA isn't navigation, it's a bluetooth app that works like a quick phone call.
Satnav:
Car Average MPG :
INTRANET
PostPosted: Sat Oct 02, 2021 3:24 am    Post subject: Reply with quote
Good news. I follow instructions and it works. I have verbal warning. But how to install update? Same way or need delete first then install.
PostPosted: Sat Oct 02, 2021 3:40 am    Post subject: Reply with quote
Once you have created a new .GPI file using POILosder........
Make sure you always use the same POILoader settings. That forces POILoader to always create the same .GPI filename and POILoader will overwrite the existing file.
Updates are weekly.
Satnav:
Car Average MPG :
INTRANET
PostPosted: Sat Oct 02, 2021 7:15 am    Post subject: Reply with quote
Thanks. Can you share what settings do you have?
I have set like this:
Maybe I miss something.
PostPosted: Sat Oct 02, 2021 7:54 am    Post subject: Reply with quote
I've got overspeed set to 6 secs. Is 3 seconds enough warning if you're still going too fast ?
Up to you though.
Satnav:
Car Average MPG :
