alan_sh Lifetime Member
Posted: Sun Sep 29, 2019 11:48 pm Post subject: 2599 won't update map to MicroSD card |
I've got a Nuvi 2599 - had it for ages.
Latest set of maps came out and I thought I'd do an upgrade.
So, Garmin Express - normal upgrade. It tells me I can put the complete set of maps onto my MicroSD card (32Gb). Great.
As an aside, I have a Window open with the drives - it shows my Nuvi and my memory card (29.7Gb free).
The map download goes OK - it activates it. Once it starts to copy to the device, the window showing the drives loses the Nuvi and only shows the memory device - which is not reducing in free space.
Gets near to the end - and then I get a red screen saying the installation has failed - which is quite likely if it's lost access to my actual device.
When I look at the memory card, it's still empty.
Anyone got any ideas on how I can fix this? Or is my device kaput?
Alan |
PhilHornby Frequent Visitor
Joined: Dec 07, 2006 Posts: 561 Location: North Devon
Posted: Mon Sep 30, 2019 2:38 am Post subject: Re: 2599 won't update map to MicroSD card |
alan_sh wrote: | Gets near to the end - and then I get a red screen saying the installation has failed - which is quite likely if it's lost access to my actual device.
I recently had some very similar symptoms, when updating a Nuvi 3598...
In my case, I know the USB connector is dodgy - in the end, I had the Nuvi at 45degrees, using its weight to keep the USB plug in contact with its socket.
Failing that - if you have a copy of the GarminDevice.xml from the device - you can put it on the SD card and update that instead. (I did this the previous time I updated the 3598)
It could of course, just be Garmin Express being it's normal, wonderful self  |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4404 Location: West Sussex
Posted: Mon Sep 30, 2019 7:24 am Post subject: |
Or maybe your PC put the USB port to sleep? In any case cloning your sd card is probably the way forward, note though the xml file needs to be in a folder named Garmin on the card and delete the xml file once the map is on the card. _________________ Where there's a will ... there's a way. |
Posted: Mon Sep 30, 2019 9:46 am Post subject: |
This happened on 2 PCs - and the system was active all the time.
How do I clone an SD card?
Alan |
Posted: Mon Sep 30, 2019 9:52 am Post subject: |
As Phil explained, but place the xml file in the Garmin folder as I explained. Express will then treat your card as the device and install the map to it. If you have a card reader for your PC even better as it will then resolve any usb issues. _________________ Where there's a will ... there's a way. |
Posted: Mon Sep 30, 2019 9:58 am Post subject: |
I'll try that - thanks.
I'm not sure about the USB port being faulty. I just did an update of the whole of Eastern Europe to the main memory and that worked fine.
Alan |
Posted: Mon Sep 30, 2019 10:13 am Post subject: |
Well that would have taken less time, there may be a time out issue. Out of interest I updated my wife's 2508 yesterday with the full EU map and it completed in just under 30 minutes. _________________ Where there's a will ... there's a way. |
Posted: Mon Sep 30, 2019 11:19 am Post subject: |
Yes, but the port disappears as soon as it starts to try and copy to the SD card. I have a 500Mb/sec breadband link....
When I installed to main memory, the port didn't disappear.
Alan |
Posted: Mon Sep 30, 2019 12:45 pm Post subject: |
Strange, suspect that's an issue with your PC then _________________ Where there's a will ... there's a way. |
Posted: Mon Sep 30, 2019 12:57 pm Post subject: |
Both my PC and my laptop? I doubt it
Anyway, I've done something with the SD card and seem to have a range of maps on there now.
Alan |
Posted: Mon Sep 30, 2019 1:29 pm Post subject: |
Done something? What? Anyway glad it's resolved, or is it? _________________ Where there's a will ... there's a way. |
BigJohnD Frequent Visitor
Joined: Aug 26, 2007 Posts: 382 Location: Glannau Mersi, Lloegr
Posted: Mon Sep 30, 2019 3:47 pm Post subject: |
Could be an iffy SD Card… Can you try another? |
Posted: Mon Sep 30, 2019 3:57 pm Post subject: |
I can try next time I have a spare 32gb card.
I used Phils method and installed the maps from my PC using the DC ard reader. That worked OK
Alan |
Posted: Mon Sep 30, 2019 4:57 pm Post subject: |
Don't forget to delete the xml file off the card. _________________ Where there's a will ... there's a way. |
Posted: Mon Sep 30, 2019 6:25 pm Post subject: |
Why?
Alan |
