MalT Occasional Visitor
Joined: 19/04/2003 10:34:17 Posts: 24 Location: United Kingdom
Posted: Sat Sep 18, 2004 5:55 pm Post subject: |
I will just have to wait then.....
Thanks for your help.
Mal |
mcwarre Regular Visitor
Posted: Sun Sep 19, 2004 11:05 am Post subject: |
Gents,
Back on topic.
Is it worth buying the Co-pilot with its own GPS receiver (approx £220) or just the software (£130) with another (better?) bluetooth GPS rx?
Thanks |
Darren Frequent Visitor
Posted: Sun Sep 19, 2004 11:14 am Post subject: |
There are better receivers IMHO, the Fortuna ClipOn is a good option and has a replaceble battery. Assuming you can get the software and a ClipON for a similar price to the CoPilot bundle then it would be a better option. _________________ Darren Griffin |
technik Lifetime Member
Joined: Mar 18, 2004 Posts: 789 Location: Midlands UK
Posted: Sun Sep 19, 2004 5:52 pm Post subject: |
How much free space is there on the supplied TTMobile MMC card ?
My present 32MB MMC is nearly full, so would need the extra space for existing programs. |
SL33PYH34D Occasional Visitor
Posted: Mon Sep 20, 2004 1:32 am Post subject: |
Anyone know if it is likely that a UIQ version will be available for the P910i? I am also fairly sure that one of the new features of the P910 over the P900 is that it does support concurrent Bluetooth connections.
I'm also hoping they produce a software only version as the TomTom blueooth receiver is not my GPS unit of choice. |
Posted: Mon Sep 20, 2004 8:04 am Post subject: |
The UIQ handsets were certainly in the original line-up but a compatible version has been delayed. I have no firm detais on if or when this will now be available. _________________ Darren Griffin |
sneals2000 Occasional Visitor
Posted: Sat Sep 25, 2004 1:51 pm Post subject: Re: Camera Database |
MikeB wrote: | MalT wrote: | but I can't seem to find how to transfer the camera POI to my new TTM that arrived earlier.
Mal
All you need to do is to copy the OV2 and BMP files into the Great-Britain-Map directory then go through the configuration options as described in the GO article (the interface works exactly the same) Click here for the article. |
Hi there
Apologies if I am missing the obvious (this is my first post here!) - but I have transferred the .ov2 and .bmp files into my Great Britain Map directory on the MMC card I got with my TTM. However when I run TTM (on a Nokia 6600) it doesn't seem to see the new POI. I can't see an "import" or similar - is there a trick I am missing to get TTM to "see" the .ov2 file?
I tried following the GO instructions - but they seem to imply that all you need to do is import the file?
Do you have to create a custom POI category manually?
All help gratefully received - apart from failing to do this I'm really pleased with the whole TomTom experience. |
MikeB Frequent Visitor
Joined: 20/08/2002 11:51:57 Posts: 3859 Location: Essex, UK
Posted: Sat Sep 25, 2004 2:06 pm Post subject: |
To 'see' the POIs go to : change preferences>maintain POI>Enabld/Disable POI then check the poi category associated with the ov2 file you want to view.
THis should get the .bmp files displayed on the screen _________________ Mike Barrett |
Posted: Sat Sep 25, 2004 2:52 pm Post subject: |
MikeB wrote: | To 'see' the POIs go to : change preferences>maintain POI>Enabld/Disable POI then check the poi category associated with the ov2 file you want to view.
THis should get the .bmp files displayed on the screen |
Thanks - thats what I thought - but when I do this the new database I've copied into the folder doesn't appear in the list of POIs to enable/disable. I've tried renaming it to something shorter - but still no joy. However if I try and create a custom POI of my own with the same name as the renamed files (say Gatso) it says it already exists.
I tried creating a POI called Gatso, before I dragged the files across, and a .ov2 and .bmp file were created - when I replaced these files with the renamed versions of the PocketGPS ones they didn't appear in the POI list...
The files I am importing are : pocketgps_uk_gatso.bmp and .ov2
Dragging and dropping across into the Great Britain Map directory using Nokia PC Suite. (All file conversion switched off)
I'm a bit stumped - I'm sure I'm not doing something obvious...
(I ensured TomTom Mobile wasn't running at the time I imported, and have also tried powering down the phone)
Any more thoughts? Are you running the Symbian or Windows version? (Could this be a bug in the Symbian sw?) |
Posted: Sat Sep 25, 2004 3:00 pm Post subject: |
Are you sure you have copied the .ov2 and .bmp files for each database into the map folder? _________________ Darren Griffin |
Posted: Sat Sep 25, 2004 3:42 pm Post subject: |
Darren wrote: | Are you sure you have copied the .ov2 and .bmp files for each database into the map folder? |
I downloaded the "pocketgps_uk_sc.zip" file, unzipped it and copied over the two files "pocketgps_uk_gatso.ov2" and "pocketgps_uk_gatso.bmp" into the Great Britain Map directory on the MMC card in the Nokia. This is the same folder that a test custom POI file appeared in when I created it in TomTom.
AIUI a new POI should have appeared in the TomTom Enable/Disable POI list called "pocketgps_uk_gatso"?
I'll try using an MMC card reader rather than the Nokia PC Suite software - just in case that is the cause? |
Posted: Sat Sep 25, 2004 3:49 pm Post subject: |
you could also try shortening the name down to gatso.ov2 and gatso.bmp _________________ Mike Barrett |
Posted: Sat Sep 25, 2004 3:51 pm Post subject: |
Whadyaknow... Copying the files using an MMC reader/writer seems to have done the trick - or something else flukey has happened.
I put the card in the reader connected to my windows machine - saw the two pocket_gps files there in Explorer. Deleted them, then dragged them across again, put the card back in my phone, switched it on, ran TomTom and it found them straight away.
Looks like Nokia PC Suite was doing something funny? (I was connected via IR rather than Bluetooth)
Strange - thanks to all for keeping me on the right track. |
bis96gw Occasional Visitor
Posted: Sun Sep 26, 2004 7:42 pm Post subject: |
Anyone know if TTM will be available on its own? I've already got a Fortuna Clip-on so don't need another receiver!! |
