Pocket GPS World :: View topic - Slow Map Rotation
Slow Map Rotation
shaun43uk
PostPosted: Sat Sep 22, 2012 4:16 pm    Post subject: Slow Map Rotation Reply with quote
Hi All
Since updating my map I'm finding my maps are very slow to rotate to the direction Im facing, Im a delivery driver and find myself down many cul de sacs and when I turn round it seems to take a while for the map to rotate and correct its position, it gets frustrating when Im sitting a a junction not knowing whether to turn left or right while the map is still pointing into a cul de sac, Ive reset the device and update the gpsfix regularly.
I also backed up and clean installed software and maps but its still slow.
my deice is 930T
maps 895.4438
app v91430
any advice would be appreciated
Tom Tom Go 5100
PostPosted: Sat Sep 22, 2012 5:29 pm    Post subject: Reply with quote
Do you have any POIs Enabled? This can slow the Map Redraw rate down dramatically. Very often a Map Update will, by default, enable some POIs.
If you need to be aware of several POI categories, consider using Warn When Near, as this doesn't impact on the Map Redraw.
shaun43uk
PostPosted: Sat Sep 22, 2012 5:38 pm    Post subject: Reply with quote
thankyou for you reply oldboy, the only poi's enabled are shell and total garages. Mcdonalds and all the pocketgps cameras
Tom Tom Go 5100
PostPosted: Sat Sep 22, 2012 8:47 pm    Post subject: Reply with quote
shaun43uk wrote:
... and all the pocketgps cameras
Do you mean Enabled and Warn When Near?
Even 4 POIs enabled to Show on Map will slow the redraw down.
shaun43uk
PostPosted: Sun Sep 23, 2012 5:57 am    Post subject: Reply with quote
yes they were enabled and warn near, Ive now disabled them, strange thought cos I never enabled them in the first place, when I updated my maps I just did the usual and put all the camera and voice files in the map folder and did the warn near thing. I'll test it this morming and let you know how it performs later.
Thanks for your help
Tom Tom Go 5100
shaun43uk
PostPosted: Thu Sep 27, 2012 2:05 pm    Post subject: Reply with quote
working great now, map almost redraws faster than I can turn around.
Tom Tom Go 5100
tonygold
PostPosted: Thu Sep 27, 2012 11:20 pm    Post subject: Reply with quote
Interesting. Not wanting to sound stupid but how do I disable my poi's but allow them to be shown when near. At the moment I think I have all speed cameras and other poi's enabled and my maps are very slow to draw.
Thank you.
PostPosted: Fri Sep 28, 2012 12:35 am    Post subject: Reply with quote
Easy peasy...
On a TomTom there are two places to set up your view of POIs
The first is "Show POIs on map"
On an older TomTom that's in Change preferences, page 1
On a new one its Settings, page 1
Tick that box and the icons will be visible on the "View map" screen and the normal driving view all the time.
The second way is the "Warn when near" set-up.
That's done in Change preferences (or Settings) / Manage POIs / Warn when near POIs
When you've set that up for each POI type you wan, the icons will only appear on the driving view when you get within the trigger distance you set.
So to achieve the fastest screen re-draws, try to keep the POIs you have set to "View on map" to a minimum, and use the "Warn when near" for them instead.
"Settling in nicely" ;-)
tonygold
PostPosted: Fri Sep 28, 2012 7:22 am    Post subject: Reply with quote
Andy_P wrote:
Easy peasy...
many thanks as ever andy.
tonygold
PostPosted: Fri Sep 28, 2012 7:32 am    Post subject: Reply with quote
Andy_P wrote:
On a TomTom there are two places to set up your view of POIs....
ok i know this is going to sound stupid but....
i have tomtom XL Live, if i go to change preferences, manage poi's, i get options to edit poi, delete poi, warn when near etc. do i delete a poi or poi category? if i do this will the poi's still be available to me to set them as warn when near poi or will i have deleted them from my device completely?
sorry to sound stupid but not had the need to alter this before but my redraw speed is just so slow i wanted to try out the suggestions above.
PostPosted: Fri Sep 28, 2012 8:45 am    Post subject: Reply with quote
tonygold wrote:
if i go to change preferences, manage poi's, i get options to edit poi, delete poi, warn when near etc. do i delete a poi or poi category? ...
No. Don't do that.
The first thing to do is go to Change Preferences, and on Page 1 is an Icon labelled Show POI on map.
Tap this and you will get a screen of POIs. On this screen Un-tick everything that is ticked.
Once you have done that you can use Warn when Near.
Finally, if you really want to see any POIs all the time, you can then repeat the first step again, to tick them, but only if it's really necessary. Even 4 selected makes a difference to screen redraw.
You will have removed them from the Device.
tonygold
PostPosted: Fri Sep 28, 2012 11:36 am    Post subject: Reply with quote
Many thanks for your clear instructions Richard. I have now done all this.
PostPosted: Fri Sep 28, 2012 1:44 pm    Post subject: Reply with quote
That's right. I've never understood why "Show POI on map" is not in "Manage POIs" with all the rest of the POI stuff. Confused
Guivre46
PostPosted: Fri Sep 28, 2012 10:48 pm    Post subject: Reply with quote
5 years i've been using these devices and never thought of that. Many thanks Oldboy and Andy P.
Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom
alanlakes
PostPosted: Sat Sep 29, 2012 9:13 am    Post subject: Reply with quote
Same here.
Tomtom Go 6200, Tomtom GO Android app, Garmin GPSMap 62stc, Garmin Oregon 450, Memory map V5 & V6, Moto G6, CamerAlert, Copilot Premium, MM Tracker.
22.034 (27 Mar 24)
