Pocket GPS World :: View topic - French and Swiss speed camera alerts
rogersouth
PostPosted: Fri Jul 27, 2012 11:04 am    Post subject: French and Swiss speed camera alerts Reply with quote
Is it possible to ensure that French and Swiss speed camera alerts are downloaded only to the SD card of a GARMIN nuvi using POI loader (so that it may be removed if stopped)?
dales
PostPosted: Fri Jul 27, 2012 12:28 pm    Post subject: Reply with quote
Yes, just put your SD card in a card reader and plug it into the PC.
PoiLoader will find it and treat it as a Garmin device.
Dales.
rogersouth
PostPosted: Fri Jul 27, 2012 1:16 pm    Post subject: Reply with quote
Thanks Dales, that`s brilliant.
inspiredron
PostPosted: Sat Jul 28, 2012 1:12 am    Post subject: Reply with quote
But when you switch your Garmin on it will then ask you if you want to make the new Extras data available if you remove the card. You MUST respond No or the Poi's will be copied to the Garmin!
rogersouth
PostPosted: Sat Jul 28, 2012 9:26 am    Post subject: Reply with quote
.............. and you don't necessarily need a separate card reader if your computer recognizes the SD slot as a separate drive you can load directly to this by using the drop down menu in POI loader.
