stevem999 Occasional Visitor
Posted: Fri Apr 27, 2012 9:22 am Post subject: |
Great 'app', really needed. However just one suggestion - can you get the page to initiate the GPS for a bit longer. My GPS turned on for all of about 5 seconds and then the page said it couldn't find a signal and suggested a manual search. Any GPS is likely to take longer than that! Cheers |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 14890 Location: Bradford, West Yorkshire
Posted: Fri Apr 27, 2012 9:32 am Post subject: |
stevem999 wrote: | Great 'app', really needed. However just one suggestion - can you get the page to initiate the GPS for a bit longer. My GPS turned on for all of about 5 seconds and then the page said it couldn't find a signal and suggested a manual search. Any GPS is likely to take longer than that! Cheers |
What device is it? Generally I've found both iPhone and my Android Motorola Atrix are able to get a good fix in the time given. You can always tap the 'Location' button again and it will start the automatic location off?
MaFt |
AliOnHols Pocket GPS Verifier
Posted: Fri Apr 27, 2012 9:45 am Post subject: |
M8TJT wrote: | AliOnHols wrote: | Oldboy wrote: | Human nature I'm afraid. Someone else will do it.  | Very true Oldboy. Sad really. | I think that OB's reply should have been reworded slightly to "Well, why have you not submitted all the lovely POIs in Madrid?"  |
Ok, I'll take the bait.
No sooner said than done. Simples.
Never having been to Madrid It's not something I felt qualified to do. But, I've just submitted the six I mentioned above (Barajas Airport has 4 terminals). _________________ Garmin Nuvi 2599
SatMap Active 10 & 20.
253 Lifetime Member
Joined: Mar 05, 2007 Posts: 1058 Location: The green bit between the M40, M4 and M25.
MaFt wrote: | [
MaFt |
Hi MaFt,
My Sensation takes for ever and a day to get a GPS fix. If I am in a house by the window with a clear view of the sky it takes about 4-5 mins. OK I know not ideal conditions but TT720 gets a fix in about 15 secs.
When I go out to the car I turn GPS on before I leave the house, set the phone up n the car on the dash and then again have to wait another 3-4 mins to get a fix. Quite often I have had to drive away with no GPS fix, and for it to spring into life some 10 miins later.
May be my phone or it may be HTC, whatever, GPS is very slow for me. Once it is going it is no problem. _________________ Triumph Tbird 1700. And now a Bonnie T100. |
Posted: Fri Apr 27, 2012 9:49 am Post subject: |
Does it get it if you tap 'Location' again a couple of times?
MaFt |
Posted: Fri Apr 27, 2012 9:53 am Post subject: |
MaFt wrote: | stevem999 wrote: | Great 'app', really needed. However just one suggestion - can you get the page to initiate the GPS for a bit longer. My GPS turned on for all of about 5 seconds and then the page said it couldn't find a signal and suggested a manual search. Any GPS is likely to take longer than that! Cheers |
MaFt |
Samsung Galaxy S2 - tried the location button a few times and it just turns on the GPS for about 5 seconds each time and then shows the message about not finding location and suggests a manual search.
Cheers |
Posted: Fri Apr 27, 2012 10:41 am Post subject: |
Hmm... My brother has the S2, as does Darren ad neither reported a similar issue.
Silly questions time:
1) Is GPS turned on?
2) Did you give permission for the site to use your location?
Not so silly question:
3) Are you using the stock Android browser? I couldn't get it to work using Firefox Mobile even though I gave it permission to use my location.
MaFt |
Darren Pocket GPS Staff
Posted: Fri Apr 27, 2012 10:47 am Post subject: |
I have an SGII running ICS and it works fine for me. Just checked, cold start.
Activated GPS, loaded page, tapped 'Location' and it pinpointed me. _________________ Darren Griffin - Editor |
Posted: Fri Apr 27, 2012 11:01 am Post subject: |
MaFt wrote: | Hmm... My brother has the S2, as does Darren ad neither reported a similar issue.
MaFt |
Thanks MaFt, relatively new Android user and didn't know there was a setting to let websites use location info. GPS was on and was using the stock browser but didn't have the location setting turned on. Just found that and activated it and now seems to be working. |
bestyman Pocket GPS Verifier
Posted: Fri Apr 27, 2012 11:03 am Post subject: |
What a fantastic "app", Thank you.
This will be very usefull when out in the motorhome to find nearby pubs, fuel etc.
It even finds my location from my laptop at home without gps, I assume it uses wifi?
If I was you I would make this into an iphome app and sell it. Im sure that it would do well. |
JQL Occasional Visitor
Joined: Apr 07, 2006 Posts: 7 Location: Lancashire & France
Posted: Fri Apr 27, 2012 11:45 am Post subject: |
Sat on a campsite in France (getting wet ) near Paris and my nearest 5 swimming pools are in....
Eastbourne and the south coast of England  _________________ John
E-TEN M700 with TomTom
Free Avatar Sizing software Avatar Sizer |
AntonM Regular Visitor
Joined: Apr 05, 2006 Posts: 61 Location: Stafford, UK
Posted: Fri Apr 27, 2012 12:21 pm Post subject: |
It won't automatically find my location on my HTC Desire. (Manual location works, of course.)
After the first few failed attempts, I ran SpeedView (which shows satellites as it fins them), waited till it had a fix, and retried PGPSW POI, which still couldn't auto-locate me.
Then I ran CamerAlert and waited till it had a fix (and updated the databse) and retried PGPSW POI, which still failed to auto-locate me.
Then I ran Google Maps as well and waited till it found me, and retried PGPSW POI (now having three other GPS apps running successfully) -- and it still failed to auto-locate me.
What am I doing wrong?
Anton _________________ Anton |
joneskdale Lifetime Member
Joined: Aug 13, 2006 Posts: 12 Location: United Kingdom
Posted: Fri Apr 27, 2012 1:28 pm Post subject: |
Nice work with the App - Something that is needed.
Had a look around and the App seems to work well some sections look to have good data. Supermarkets seem to work well. But as always the problem is getting up to date data. Hopefully PocketGPSWorld can pull this off by using their team of subscribers that are already used to submitting speed cameras.
There is a lot of data missing.
I tried Banks - Halifax - This didn't do very well - Didn't find either of two banks nearest to work.
I tried Specsavers - Didn't do very well either - Missed the nearest three at least.
I tried Fuel - Here I really only wanted to see Petrol and Diesel but it showed mostly Calor Gas.
I was using an iPad3. Didn't find location first time but second attempt worked.
Can I make one suggestion for the program. I know you can specify how many to find default 5 but it would be great if after it has found the 5 there was a button that said "MORE" so you could get say the next 5 without having to go back and resubmit etc. This would be a great usability improvement.
Lastly would it be possible to have send to car (BMW) the same as you can do from Google Maps., or the BMW Remote App for the iphone?
Gladly help with any details and testing. |
alanlakes Lifetime Member
Joined: Dec 28, 2005 Posts: 98 Location: Chevington, Suffolk
Posted: Fri Apr 27, 2012 1:30 pm Post subject: |
AntonM
Had same problem. Checked previous posts and you need to turn on the location setting in your browsers settings. I use the browser that comes loaded with my HTC desire HD.
Regards
Alan _________________ Tomtom Go 6200, Tomtom GO Android app, Garmin GPSMap 62stc, Garmin Oregon 450, Memory map V5 & V6, Moto G6, CamerAlert, Copilot Premium, MM Tracker. |
Posted: Fri Apr 27, 2012 2:44 pm Post subject: |
joneskdale wrote: | There is a lot of data missing. |
Add it :D
joneskdale wrote: | Can I make one suggestion for the program. I know you can specify how many to find default 5 but it would be great if after it has found the 5 there was a button that said "MORE" so you could get say the next 5 without having to go back and resubmit etc. This would be a great usability improvement. |
Ooh, now I like that idea!
joneskdale wrote: | Lastly would it be possible to have send to car (BMW) the same as you can do from Google Maps., or the BMW Remote App for the iphone?
Does the BMW remote app allow users to send locations to it via SMS or weblink etc? Ditto for the car - how would you normally get a lcoation sent to the car?
MaFt |
