fabman Occasional Visitor
Posted: Mon Jul 12, 2010 1:54 pm Post subject: 3 maps |
hi is it possible to load new uk maps and keep my old map on if new maps are ok then i could remove the old uk map thanks fabman |
Andy_P Pocket GPS Moderator
Posted: Mon Jul 12, 2010 3:48 pm Post subject: |
A bit hard to answer properly without knowing what model you are running!
You could move the maps onto different SD cards if your model has a card slot.
You can also edit the name of the map in the the ID= line in each map's .pna file. |
Posted: Mon Jul 12, 2010 5:24 pm Post subject: xl iq routes |
hi im using a xl iq routes editin not the tm2 2gig internal memory uk and ireland maps 525.2159 read that i can use the latest 845 maps got the latest navcore the map i have on it shows the a49 as the a50 dont know why the a49 is yeara old
thanks |
Posted: Mon Jul 12, 2010 7:38 pm Post subject: |
You won't have room to fit both maps on the internal memory at once.
Use Home or windows Explorer to move the old map to your computer before you download the new one.
Back the whole thing up again with Windowss Explorer.
Then you can use Home to move the two maps between the PC and the XL. |
Posted: Mon Jul 12, 2010 7:43 pm Post subject: 3maps |
cheers for that i shall try it thanks |
