Pocket GPS World :: View topic - 3 maps
3 maps
fabman
PostPosted: Mon Jul 12, 2010 1:54 pm    Post subject: 3 maps Reply with quote
hi is it possible to load new uk maps and keep my old map on if new maps are ok then i could remove the old uk map thanks fabman
PostPosted: Mon Jul 12, 2010 3:48 pm    Post subject: Reply with quote
A bit hard to answer properly without knowing what model you are running!
You could move the maps onto different SD cards if your model has a card slot.
You can also edit the name of the map in the the ID= line in each map's .pna file.
fabman
PostPosted: Mon Jul 12, 2010 5:24 pm    Post subject: xl iq routes Reply with quote
hi im using a xl iq routes editin not the tm2 2gig internal memory uk and ireland maps 525.2159 read that i can use the latest 845 maps got the latest navcore the map i have on it shows the a49 as the a50 dont know why the a49 is yeara old
thanks
PostPosted: Mon Jul 12, 2010 7:38 pm    Post subject: Reply with quote
You won't have room to fit both maps on the internal memory at once.
Use Home or windows Explorer to move the old map to your computer before you download the new one.
Back the whole thing up again with Windowss Explorer.
Then you can use Home to move the two maps between the PC and the XL.
fabman
PostPosted: Mon Jul 12, 2010 7:43 pm    Post subject: 3maps Reply with quote
cheers for that i shall try it thanks
22.053 (15 May 24)
