trickpalmer Occasional Visitor
Posted: Fri May 21, 2010 11:57 am Post subject: tomtom 720t not recognising RDS-TMC |
Can anyone help please. I plug the aerial in but nothing happens.
Any advice would be appreciated. |
Posted: Fri May 21, 2010 1:22 pm Post subject: |
If its the Mini-USB style receiver are you sure its got power to it as they don't work without, if its the round style plug on the receiver have a close look at the socket it fits in and does appear broken/ bits missing etc, also these can require quite a firm push to get them to sit in the socket fully - Mike |
Posted: Fri May 21, 2010 1:41 pm Post subject: |
Hi thanks for the quick reply its the round type, the plug & socket look fine. |
Andy_P Pocket GPS Moderator
Posted: Tue May 25, 2010 8:24 pm Post subject: |
Try all the usual things:
1. a reboot
2. a return to factory settings
3. reinstalling the software
(Moved to TomTom forum section) |
sphelps Lifetime Member
Posted: Tue May 25, 2010 8:40 pm Post subject: |
I had the same trouble. Luckily I had a spare one which worked straight away.
I did notice that the new one fitted tighter than the old one, so maybe it's wear and tear on the plug itself _________________ Regards
Steve
TomTom 720 Version 8.302 Map WCE v825
Navigon 40 Premium |
DinAlt Regular Visitor
Posted: Tue May 25, 2010 11:22 pm Post subject: |
The plugs aren't very well made - especially as the wire pretty much has to do a right angle direction change as soon as it leaves the connection.
Try connecting it and adjusting the direction/angle you have it coming out of the nav unit. my first one would only work if it was under tension - I presume this was a sign of a loose connection under the plug cover - you might be able to coax some more life out of yours by experimenting - doubt it'd be a permanent fix though (my cable was eventually stolen and the replacement one has so far not shown the same problem).
DinAlt |
