Pocket GPS World :: View topic - tomtom 720t not recognising RDS-TMC
trickpalmer
PostPosted: Fri May 21, 2010 11:57 am    Post subject: tomtom 720t not recognising RDS-TMC Reply with quote
Can anyone help please. I plug the aerial in but nothing happens.
Any advice would be appreciated.
PostPosted: Fri May 21, 2010 1:22 pm    Post subject: Reply with quote
If its the Mini-USB style receiver are you sure its got power to it as they don't work without, if its the round style plug on the receiver have a close look at the socket it fits in and does appear broken/ bits missing etc, also these can require quite a firm push to get them to sit in the socket fully - Mike
trickpalmer
PostPosted: Fri May 21, 2010 1:41 pm    Post subject: Reply with quote
Hi thanks for the quick reply its the round type, the plug & socket look fine.
PostPosted: Tue May 25, 2010 8:24 pm    Post subject: Reply with quote
Try all the usual things:
1. a reboot
2. a return to factory settings
3. reinstalling the software
(Moved to TomTom forum section)
sphelps
PostPosted: Tue May 25, 2010 8:40 pm    Post subject: Reply with quote
I had the same trouble. Luckily I had a spare one which worked straight away.
I did notice that the new one fitted tighter than the old one, so maybe it's wear and tear on the plug itself
Regards
Steve
TomTom 720 Version 8.302 Map WCE v825
Navigon 40 Premium
DinAlt
PostPosted: Tue May 25, 2010 11:22 pm    Post subject: Reply with quote
The plugs aren't very well made - especially as the wire pretty much has to do a right angle direction change as soon as it leaves the connection.
Try connecting it and adjusting the direction/angle you have it coming out of the nav unit. my first one would only work if it was under tension - I presume this was a sign of a loose connection under the plug cover - you might be able to coax some more life out of yours by experimenting - doubt it'd be a permanent fix though (my cable was eventually stolen and the replacement one has so far not shown the same problem).
DinAlt
23.044 (23 Apr 25)
