Pocket GPS World :: View topic - bt mobile data connection settings
R3vel
PostPosted: Sat Nov 08, 2008 6:45 pm    Post subject: bt mobile data connection settings Reply with quote
Hi all
I have a TomTom 520 and a HTC S620 on BT Mobile.
I have paired them and the problems startwhen I come to do the wireless connection.
I select other because my phone isnt listed.
I then select UK.
I then have to click other for operator because for some reason BT isnt listed
It then says set up wireless manually..Yes
From searching the net, i got these settings:
Access point name: btmobile.bt.com
User name: bt
Password: [none]
IP address (DHCP): Automatic
DNS Server: Automatic
Dial: *99#
Login script: at+cgdcont=1,"IP","btmobile.bt.com"
It then says checking wireless data settings.........
Then, Unable to set up your wireless data connection. Do you want to change your settings?
Im stumped. What now?
Any help always welcome
Andy
PostPosted: Sat Nov 08, 2008 6:49 pm    Post subject: Reply with quote
Is the phone running WM5 or WM6? neither have the required Bluetooth DUN profile available which the TomTom requires for the data connection, there is a CAB file to install the missing profile to the PDA based phones but I am not too sure if it will work with the non touch screen MS SmartPhone - if you want to try it I can provide a link, but if it goes wrong you might have to hard reset the phone - Mike
R3vel
PostPosted: Sat Nov 08, 2008 6:57 pm    Post subject: Reply with quote
Thanks for the reply
I have done the Dun thing with the cab file as I wasnt even getting as far as i did. When they are paired, everything works except for the GPRS connection to use TT services
PostPosted: Sat Nov 08, 2008 7:29 pm    Post subject: Reply with quote
Some phones simply won't work with the TomTom devices, unless they are listed as compatible on the TT Web site there is very little that can be done, you have already tried the first dodge to enable the DUN profile and that’s about as far as I can advise with WM based phones - Mike
R3vel
PostPosted: Sat Nov 08, 2008 8:24 pm    Post subject: Reply with quote
Thanks for the help mike.
After a bit of digging, it looks like the BT network piggybacks on the Vodafone network.
Will try that and let you know
Thanks again
Andy
PostPosted: Sat Nov 08, 2008 8:56 pm    Post subject: Reply with quote
My only other thoughts on this issue is whether you have a contracted mobile phone i.e. you pay each month or is it a Pay As You Go service you are using, not all PAYG services offer true GPRS connectivity.
Even if you have got a contracted mobile phone service you might need to get GPRS enabled on your contract as the standard WAP service tends to be offered by default but this isn't compatible with the TomTom servers - Mike
R3vel
PostPosted: Sat Nov 08, 2008 10:14 pm    Post subject: Reply with quote
Thanks for the info. Im on contract and the network is 3G with BT.
Will let you know if i get it resolved.
Andy
R3vel
PostPosted: Sat Nov 08, 2008 11:25 pm    Post subject: Reply with quote
Hows this for a work around.
I went through the normal setup for wireless connections, but knowing that Vodafone has something to do with it, I inserted those details, but also knowing that im on a BT contract, I put the BT settings in manually, guess what?????? It works. I have now managed to pair it all up and also get the wireless connection so i can use tomtom services. Nice to see what the weather is doing. Beats opening the curtains to see Smile
I wondnt be suprised if tomtom decided to give in as ive been punching its screen for the past 5 hours.
Thanks Mike
playswell
PostPosted: Sun Nov 09, 2008 2:01 pm    Post subject: Reply with quote
Thanks Mike
APN address : btmobile.bt.com
Username : bt
Password: bt
Thats what you should be using
R3vel
PostPosted: Sun Nov 09, 2008 2:08 pm    Post subject: Reply with quote
Those are the settings im using, but for some reason with me inputting vodafone as my network provider and using the BT settings, it seems to have worked. Dont know why, but it does. Smile
22.044 (24 Apr 24)
