Pocket GPS World :: View topic - Tom Tom Go rebooting itself
Mikeuk
PostPosted: Thu Sep 25, 2008 4:49 pm    Post subject: Tom Tom Go rebooting itself Reply with quote
I bought a new TomTom Go 530 I have had it a few weeks now, but recently it’s been rebooting itself when I switch it on and one day would not switch on at all until I did a reset.
Is this a common problem with this device?
Should I return it?
Mikeuk
PostPosted: Fri Sep 26, 2008 9:41 am    Post subject: Reply with quote
Ok did reset as advised on the Tom Tom website, this worked for a few minutes. How ever when you first switch it on now and navigate through various menus the screen just freezes then the unit reboots? And the route I planned has gone.
Looks like I will have to return this one.
Thanks any feed back appreciated
Confused
Wishlist
PostPosted: Fri Sep 26, 2008 10:12 am    Post subject: Reply with quote
Confused
How much free space have you got left?
Mikeuk
PostPosted: Fri Sep 26, 2008 10:18 am    Post subject: Reply with quote
Thanks its got 607.3mb free of internal memory.
hollis_f
PostPosted: Fri Sep 26, 2008 11:15 am    Post subject: Reply with quote
I have exactly the same problem with a new 530. If it's going to do the freeze-reboot thing it'll normally do it within a couple of minutes of being switched on. If it can survive those first minutes it'll keep going for hours.
I've installed a few new voices and a lot of POIs - but I still have masses of free space.
I'm waiting for the next upgrade to see if that fixes it.
Wishlist
PostPosted: Fri Sep 26, 2008 2:18 pm    Post subject: Reply with quote
Have you run the clear flash tool?
Mikeuk
PostPosted: Fri Sep 26, 2008 4:47 pm    Post subject: Reply with quote
No I have not what does this do? I thought the reset button did this?
Mikeuk
PostPosted: Fri Sep 26, 2008 5:48 pm    Post subject: Reply with quote
I have done a reset once more and seems ok for now as in tom tom link below.
Will let you know how I get on.
Thanks all
http://www.tomtom.com/support/product.php?ID=2026&Language=1&FID=6965
PostPosted: Sat Sep 27, 2008 10:29 pm    Post subject: Reply with quote
ClearFlash tool is totally different...
Download it from the TomTom site HERE
Don't worry, despite it's name it DOESN'T delete anything vital from the internal flash memory of your unit!
gatorguy6996
PostPosted: Sun Sep 28, 2008 1:49 am    Post subject: Reply with quote
I'll let you know if clearflash worked with my 930. I thought the battery was just discharging quicker when I would turn my 930 on and get "low battery" shutdown. I run on battery most of the time as I use a nuvi 760 on the side. Until the other night when it turned itself on while on the dining room table, I hadn't put two and two together.
Garmin 1695 / 255 / 760 w/MSN - Droid w/Google nav + Navigon - Navigon 8100T - Dakota10 - GPSMap76C - GeoMate Jr.
Mikeuk
PostPosted: Sun Sep 28, 2008 11:40 am    Post subject: Reply with quote
Thanks Andy_P
Have done clearflash and seems ok I will hang onto it a bit longer and see if its ok.
Cheers Wink
Mikeuk
PostPosted: Mon Sep 29, 2008 5:30 pm    Post subject: Reply with quote
Well that did not work I am sending it back to get a refund Crying or Very sad the display still freezes and the resets its self losing the route planned.
Anyone suggest a better device?
AndyVaughan
PostPosted: Mon Sep 29, 2008 7:17 pm    Post subject: Reply with quote
Try deleting the gnsdata file and then rebooting
Andy
Anita
PostPosted: Mon Sep 29, 2008 9:42 pm    Post subject: Reply with quote
Should we all have a gnsdata file? The only file in my gns folder is TmcEApi.SO. Confused
Anita
TomTom VIA 135 - App 12.075,
UK map 1100.11689
Samsung Galaxy S8
technik
PostPosted: Mon Sep 29, 2008 10:32 pm    Post subject: Reply with quote
Try cleaning the display, especially under the frame in the corners.
It could also be the frame touching the screen.
I had a similar issue, and resolved it by running a store loyalty card all around the edges between the display and the frame.
21.014 (25 Jan 23)
