Mikeuk Occasional Visitor
Joined: Dec 08, 2004 Posts: 45 Location: north east uk
Posted: Thu Sep 25, 2008 4:49 pm Post subject: Tom Tom Go rebooting itself |
I bought a new TomTom Go 530 I have had it a few weeks now, but recently it’s been rebooting itself when I switch it on and one day would not switch on at all until I did a reset.
Is this a common problem with this device?
Should I return it?
Thanks |
Posted: Fri Sep 26, 2008 9:41 am Post subject: |
Ok did reset as advised on the Tom Tom website, this worked for a few minutes. How ever when you first switch it on now and navigate through various menus the screen just freezes then the unit reboots? And the route I planned has gone.
Looks like I will have to return this one.
Thanks any feed back appreciated
Wishlist Lifetime Member
Posted: Fri Sep 26, 2008 10:12 am Post subject: |
Mikeuk wrote: | Ok did reset as advised on the Tom Tom website, this worked for a few minutes. How ever when you first switch it on now and navigate through various menus the screen just freezes then the unit reboots? And the route I planned has gone.
| How much free space have you got left? |
Posted: Fri Sep 26, 2008 10:18 am Post subject: |
Thanks its got 607.3mb free of internal memory. |
hollis_f Regular Visitor
Joined: 11/10/2002 06:31:24 Posts: 98 Location: United Kingdom
Posted: Fri Sep 26, 2008 11:15 am Post subject: |
I have exactly the same problem with a new 530. If it's going to do the freeze-reboot thing it'll normally do it within a couple of minutes of being switched on. If it can survive those first minutes it'll keep going for hours.
I've installed a few new voices and a lot of POIs - but I still have masses of free space.
I'm waiting for the next upgrade to see if that fixes it. |
Posted: Fri Sep 26, 2008 2:18 pm Post subject: |
Mikeuk wrote: | Thanks its got 607.3mb free of internal memory. |
Have you run the clear flash tool? |
Posted: Fri Sep 26, 2008 4:47 pm Post subject: |
No I have not what does this do? I thought the reset button did this?
Thanks |
Andy_P Pocket GPS Moderator
Posted: Sat Sep 27, 2008 10:29 pm Post subject: |
Mikeuk wrote: | No I have not what does this do? I thought the reset button did this?
Thanks |
ClearFlash tool is totally different...
Download it from the TomTom site HERE
Don't worry, despite it's name it DOESN'T delete anything vital from the internal flash memory of your unit! |
gatorguy6996 Frequent Visitor
Joined: Feb 16, 2008 Posts: 695 Location: Florida, USA
Posted: Sun Sep 28, 2008 1:49 am Post subject: |
I'll let you know if clearflash worked with my 930. I thought the battery was just discharging quicker when I would turn my 930 on and get "low battery" shutdown. I run on battery most of the time as I use a nuvi 760 on the side. Until the other night when it turned itself on while on the dining room table, I hadn't put two and two together. _________________ Garmin 1695 / 255 / 760 w/MSN - Droid w/Google nav + Navigon - Navigon 8100T - Dakota10 - GPSMap76C - GeoMate Jr. |
Posted: Sun Sep 28, 2008 11:40 am Post subject: |
Thanks Andy_P
Have done clearflash and seems ok I will hang onto it a bit longer and see if its ok.
Cheers |
Posted: Mon Sep 29, 2008 5:30 pm Post subject: |
Well that did not work I am sending it back to get a refund the display still freezes and the resets its self losing the route planned.
Anyone suggest a better device?
Thanks |
AndyVaughan Lifetime Member
Joined: Apr 13, 2006 Posts: 1500 Location: Rossendale
Posted: Mon Sep 29, 2008 7:17 pm Post subject: |
Try deleting the gnsdata file and then rebooting
Andy |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Mon Sep 29, 2008 9:42 pm Post subject: |
Should we all have a gnsdata file? The only file in my gns folder is TmcEApi.SO. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21 |
technik Lifetime Member
Joined: Mar 18, 2004 Posts: 788 Location: Midlands UK
Posted: Mon Sep 29, 2008 10:32 pm Post subject: |
Try cleaning the display, especially under the frame in the corners.
It could also be the frame touching the screen.
I had a similar issue, and resolved it by running a store loyalty card all around the edges between the display and the frame. |
