Talkingbollox Frequent Visitor
Joined: 14/10/2002 15:11:34 Posts: 439 Location: United Kingdom
Posted: Sun May 23, 2004 8:53 pm Post subject: Fatal Error in TT3 |
I have encountered fatal errors in TT3. Each time it happens in the safety screen.
The safety speed for the safety screen is set at 50mph on my system. When travelling above 50mph and I tap the top half of the screen, I expect to go into Navigator options. Instead I don't get any response. I can only access the Navigator options if I touch the bottom left of the safety screen. After that it would invariably come up with a fatal error message plastered in the middle of the screen and TT3 would bomb out. If I press the shortcut button for CheckPoint TT3 would fire up again.
I would like to know if this is a general bug or is it something that only affects my system.
Please post your findings
Thanks |
Darren Frequent Visitor
Posted: Sun May 23, 2004 9:16 pm Post subject: |
Some more information on your configuration would help, Type of PDA, GPS, OS, Memory Card type and Size and what ROM Updates and TTN Revision Level you have? _________________ Darren Griffin |
Posted: Sun May 23, 2004 9:55 pm Post subject: |
Ok
iPaq 3870 running PPC 2002 ROM Revision 2.20.21 ENG
Wire GPS NMEA 4800 on Com 1, also same symptoms on Emtac sleeve
Simpletech 256mb SD card
TTN 3.01 (409), GPS driver v2.07 288/365
Thanks |
Posted: Mon May 24, 2004 7:30 am Post subject: |
OK, first thing to test, remove SD card, install 16Mb map to memory and re-test, report back if issue still presents itself? _________________ Darren Griffin |
