Pocket GPS World :: View topic - Fatal Error in TT3
Fatal Error in TT3
Talkingbollox
PostPosted: Sun May 23, 2004 8:53 pm    Post subject: Fatal Error in TT3 Reply with quote
I have encountered fatal errors in TT3. Each time it happens in the safety screen.
The safety speed for the safety screen is set at 50mph on my system. When travelling above 50mph and I tap the top half of the screen, I expect to go into Navigator options. Instead I don't get any response. I can only access the Navigator options if I touch the bottom left of the safety screen. After that it would invariably come up with a fatal error message plastered in the middle of the screen and TT3 would bomb out. If I press the shortcut button for CheckPoint TT3 would fire up again.
I would like to know if this is a general bug or is it something that only affects my system.
Please post your findings
PostPosted: Sun May 23, 2004 9:16 pm    Post subject: Reply with quote
Some more information on your configuration would help, Type of PDA, GPS, OS, Memory Card type and Size and what ROM Updates and TTN Revision Level you have?
Talkingbollox
PostPosted: Sun May 23, 2004 9:55 pm    Post subject: Reply with quote
Ok
iPaq 3870 running PPC 2002 ROM Revision 2.20.21 ENG
Wire GPS NMEA 4800 on Com 1, also same symptoms on Emtac sleeve
Simpletech 256mb SD card
TTN 3.01 (409), GPS driver v2.07 288/365
PostPosted: Mon May 24, 2004 7:30 am    Post subject: Reply with quote
OK, first thing to test, remove SD card, install 16Mb map to memory and re-test, report back if issue still presents itself?
22.052 (08 May 24)
