Pocket GPS World :: View topic - active sync not connecting
dobbo
PostPosted: Thu May 20, 2004 9:03 pm    Post subject: active sync not connecting Reply with quote
still wont connect through infra red says your device was not detected any suggestion what to do now do i need any more software on my pc
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Thu May 20, 2004 9:24 pm    Post subject: Reply with quote
You really should reply to the original ngoing topic thread rather than starting an entire new thread or we'll never get to the bottom of this. Howvere noe we're here let's stick to this one and not create any more!
No you don't need any more software, I'm no expert on iR Sync but check the following:
In ActiveSync, GoTo File | Connection Settings
Ensure 'Allow serial cable or infrared connection to this COM port:' is ticked and change the COM Port configured in this dialogue to Infrared Port (IR) then try the Sync via IR as before from the ActiveSync client on the PDA.
dobbo
PostPosted: Thu May 20, 2004 11:12 pm    Post subject: still not connecting Reply with quote
done all that but everytime i go into connetion settings it starts the sync again and dont find my ppc. my ppc says not connected but my pc nows its there as the infra red i con there and says pocket pc in range
budgie55
PostPosted: Fri May 21, 2004 1:05 am    Post subject: Reply with quote
make sure that on your pda under start>>settings>>connections>>beam
that you have the receive incoming beams ticked then tap OK.
Hope that MAY help.
Why no USB? The USB cards are so cheap now or even a USB hub. Can pick them up from 7dayshop.com and scan.co.uk or dabs.com for around £10 for the card if your puter has a spare PCI slot.
Best of luck
Allan
DavidW
PostPosted: Fri May 21, 2004 2:51 pm    Post subject: Reply with quote
What version of Windows are you using? If it's Windows 2000, you have to upgrade to Service Pack 4 before ActiveSync over IR will work (there's no IrCOMM support in earlier Service Packs).
22.051 (01 May 24)
