Pocket GPS World :: View topic - Convert European Speed camera db to MPH
DaveF1
PostPosted: Thu Aug 09, 2007 3:08 pm    Post subject: Convert European Speed camera db to MPH Reply with quote
Has anone got any software to convert the European Speed camera db so I can upload it to my i3 in MPH?
gardenshed
PostPosted: Thu Aug 09, 2007 5:46 pm    Post subject: Reply with quote
i just changed the units on the tt to kph, it was easier, if i saw a 30kph sign and the tt was indicating 30kph too easy, however divide by ten and multiply by six will give you a speed in mph on the lower safe side, ie 30kph divided by ten is 3kph multiply by six is 18 mph Wink
kph ---- mph
50 ----- 30
60 ----- 36
70 ----- 42
80 ---- - 48
90 ----- 54
100 ---- 60
110 ---- 66
120 ---- 72
130 ---- 78
as you can see if you compare to your speedo they come out just under hence as a quick guide, on the safe side
CharlieG
PostPosted: Thu Aug 09, 2007 6:09 pm    Post subject: KPH to MPH Reply with quote
A more accurate coversion would be to divide by 8 and multiply by 5, 80 KPH = 50 MPH
Charlie Gregory
iPaq 2210, Velcro mount, Viking 1GB SD, 2GB Microdrive,
4GB Kingston Elite Pro CF,TomTom 5 v5.21, Maps of Europe,
Dest 6, Maps of Europe, Memory Map Navigator (Europe Edition)
GlobalSat SDI0 SD-501 GPS, BT GPS
TT BT GPS, Inforad
gardenshed
PostPosted: Thu Aug 09, 2007 6:21 pm    Post subject: Reply with quote
but the 10/6 gives you an envelope of safety, and in my case it easier Embarassed Very Happy and at 100kph you are 2.5kph over the limit
DaveF1
PostPosted: Thu Aug 09, 2007 10:20 pm    Post subject: Reply with quote
any idea whether the GPX converter is OK with these speeds? I tried converting the CSV files to GPX (mainly so they don't list as Custom Points) forgetting to set the speeds to KPH and it threw a right wobbly...
well, it gave an error message for every one it couldn't convert. Changed the settings to KPH and it ran OK. Uploaded them to i3 but then it dawned on me that the i3 would assume the speeds were in MPH - that's what you set the POI loader to. I can't think of an easy way to upload two sets of camera dbs one in MPH and the other in KPH, apart from converting the European ones to MPH.... Confused
inspiredron
PostPosted: Fri Aug 10, 2007 4:51 pm    Post subject: Reply with quote
I don't know if it works on the I3 but you might want to look at my post here:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=57496
22.052 (08 May 24)
