Newsletter
Luxury Villa at Watersong Davenport, Orlando, Florida for rent
Pocket GPS World :: View topic - iGO Speed Camera Database Released
Goto page 1, 2, 3, 4  Next
PostPosted: Thu May 17, 2007 9:25 pm    Post subject: iGO Speed Camera Database Released Reply with quote
As from todays release (5.053) there is a version of the database available for iGO software - it is the "text file" version as mentioned in another thread.
Simply select 'iGO' on the downloads page.
linknet
PostPosted: Fri Jun 08, 2007 9:25 am    Post subject: Re: iGO Speed Camera Database Released Reply with quote
There appear to be a couple of anomalies in the PGPSW iGO Speed Camera text file.
Firstly, it isn't in true text format, each line ends in a LF (Line Feed - Hex 0A) only rather than the normal CRLF (Carriage Return + Line Feed - Hex 0D + Hex 0A).
I know that iGO still accepts this but it's non-standard and when opened in NotePad, for instance, it's not formatted correctly.
Secondly, many of the Type 3 RedLight cameras have speed information in the SPEED field rather than 0 (zero).
Again it's possible that iGO will ignore this information if the TYPE field is set to 3 , but for correctness, it still should be set to 0 (zero).
Regards
linknet
PostPosted: Fri Jun 08, 2007 10:54 am    Post subject: Reply with quote
file displays correctly in notepad for me...
linknet
PostPosted: Fri Jun 08, 2007 11:12 am    Post subject: Reply with quote
Strange ?
This is how it displays on three different machines, two WinXP-SP2 and one Vista:
This is with LF's replaced with CRLF's:
Am I doing something wrong ?
Regards
linknet
PostPosted: Fri Jun 08, 2007 11:36 am    Post subject: Reply with quote
ah, think i see the problem here.
i was checking the main file on my system as opposed to the downloaded one.
after downloading the file i get the same issue as you.
i can only assume that the process used for zipping the files on the server messes with the .txt file - certinly i've noticed it with the layout of release.txt
probably nothing we can do, but if the file works wih the igo then it shouldn't be an issue
linknet
PostPosted: Fri Jun 08, 2007 11:49 am    Post subject: Reply with quote
Yes, it's doing it with all the text files (release and licence text) in all of the PGPSW downloads.
I think your server needs a tweak Wink
Are you using a Unix/Linux based server, in which case the original text files won't contain any CRLF's, only LF's. It's unlikely that the zip is removing them, they're probably just not there to begin with.
Regards
linknet
linknet
PostPosted: Fri Jun 15, 2007 4:40 pm    Post subject: Re: iGO Speed Camera Database Released Reply with quote
linknet wrote:
Many of the Type 3 RedLight cameras have speed information in the SPEED field rather than 0 (zero).
It's possible that iGO will ignore this information if the TYPE field is set to 3 , but for correctness, it still should be set to 0 (zero).
linknet
Hi MaFt
Any chance of a reply to this second part of the question ?
Regards
linknet
PostPosted: Sat Jun 16, 2007 12:48 am    Post subject: Reply with quote
i don't have igo but alix who has tested the file for me did not have any issues with the speed setting on the redlight cams.
mk_graham
PostPosted: Wed Aug 08, 2007 2:05 pm    Post subject: Reply with quote
Short and sweet question - if I purchase and install the PGPSW IGO speed cams to my V7 PMD 1400 will it bong nicely at me if I exceed?
Garmin i3 gone (sold on eBay)
V7 PMD 1400 with Western Europe Maps gone (sold in local paper)
TomTom Go 720 WE Maps (for sale)
iPhone with Sygic Mobile Maps (Europe) - having problems
PostPosted: Wed Aug 08, 2007 2:59 pm    Post subject: Reply with quote
there is a specific download for the Myguide PND's that will work fine - the myguide units run a similar version of the igo software
mk_graham
PostPosted: Wed Aug 08, 2007 5:09 pm    Post subject: Reply with quote
Thanks for the info MaFt
mk_graham
PostPosted: Thu Aug 09, 2007 11:42 am    Post subject: Reply with quote
Hmmm, my V7 unit doesn't have a USB port to connect to the PC to load these files to the unit.
I copied these to the SD card and reading around I found instructions to 'hack' various files so that you can get WinCE explorer to run. I did this okay a copied the files from the SD to the Flash Disk\MyGuide\POI\SPEEDCAM folder and restarted the unit. All okay.
Short of driving towards a camera over the limit to check that they are working, should I be able to see the cameras in Map or Cockpit mode as I can't see them at the moment?
mk_graham
PostPosted: Sat Aug 18, 2007 10:07 pm    Post subject: Reply with quote
Okay just back from a week away with my V7 with PGPSW speed cams loaded as advised, but they don't work!! Advice: don't waste your 2 quid if you have one of these V7 units as (sorry MaFt) they are NOT the same as the MyGuide 3000; assuming that some peeps have confirmed that the speed cams work on MyGuide 3000's?? Anyone??
PostPosted: Sat Aug 18, 2007 11:15 pm    Post subject: Reply with quote
mk_graham - many apologies. please can you email mike (AT) pocketgpsworld.com and he will arrange a refund of your payment. please point him to this thread as confirmation.
thanks
Sallet
PostPosted: Sat Jun 14, 2008 4:47 pm    Post subject: Reply with quote
Regards
linknet
If you use WORDPAD rather than Notepad (type WORDPAD from the RUN command in XP) this allows editing and save as .txt keeping any CR or LF hidden in the file.
Page 1 of 4
20.013 (19 Jan 22)
Terms & Privacy
