tony553 Occasional Visitor
Posted: Fri Jan 12, 2007 5:07 pm Post subject: speed camera updates 12-01-07 |
The latest download for the i3 states 11,328 POIs after down load my unit says 11,217. All previous downloads have tallyed with the web site figure any ideas as to what's happening? the SD card is not full and I have tried three down loads with the same result. |
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Fri Jan 12, 2007 8:48 pm Post subject: |
There are definitely 11,328 POIs in the current DB, so at least the figure reported by POI Loader is correct.
How did you get the i3 to tell you how many are installed? |
Posted: Fri Jan 12, 2007 10:33 pm Post subject: |
POILoader tells you once it's finished. |
Posted: Fri Jan 12, 2007 10:52 pm Post subject: |
If POILoader is reporting the 11,217 POI loaded can you confirm you have selected the new database to actually be installed and not the previous one?
Try downloading again, unzip/ Extract the contents of the download to a known folder (select YES to the overwrite existing files of same name - yes to all is easier, if prompted) then point POILoader at the folder the new database was extracted to, and try again - Mike |
Wildie Occasional Visitor
Posted: Sat Jan 13, 2007 1:34 am Post subject: |
no idea how many it put in of the speed cams as poi loader reported to me 65k of poi`s loaded _________________ tom tom start 25
Waze |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15142 Location: Bradford, West Yorkshire
Posted: Sat Jan 13, 2007 12:48 pm Post subject: Re: speed camera updates 12-01-07 |
tony553 wrote: | The latest download for the i3 states 11,328 POIs after down load my unit says 11,217. All previous downloads have tallyed with the web site figure any ideas as to what's happening? the SD card is not full and I have tried three down loads with the same result. |
11,217 was the number in the last release. please can you confirm you have a) downloaded the newest version and b) actually told poi loader to use this new version?
MaFt |
Posted: Sat Jan 13, 2007 2:10 pm Post subject: POI download problem i3 |
I have rectified fault,Thanks. Obviously a computor glitch! Deleted the old PGPS files from the desktop and installed new,now every thing works perfect again. |
