Pocket GPS World :: View topic - speed camera updates 12-01-07
tony553
PostPosted: Fri Jan 12, 2007 5:07 pm    Post subject: speed camera updates 12-01-07 Reply with quote
The latest download for the i3 states 11,328 POIs after down load my unit says 11,217. All previous downloads have tallyed with the web site figure any ideas as to what's happening? the SD card is not full and I have tried three down loads with the same result. Sad
swing
PostPosted: Fri Jan 12, 2007 8:48 pm    Post subject: Reply with quote
There are definitely 11,328 POIs in the current DB, so at least the figure reported by POI Loader is correct.
How did you get the i3 to tell you how many are installed?
PaulB2005
PostPosted: Fri Jan 12, 2007 10:33 pm    Post subject: Reply with quote
POILoader tells you once it's finished.
PostPosted: Fri Jan 12, 2007 10:52 pm    Post subject: Reply with quote
If POILoader is reporting the 11,217 POI loaded can you confirm you have selected the new database to actually be installed and not the previous one?
Try downloading again, unzip/ Extract the contents of the download to a known folder (select YES to the overwrite existing files of same name - yes to all is easier, if prompted) then point POILoader at the folder the new database was extracted to, and try again - Mike
Wildie
PostPosted: Sat Jan 13, 2007 1:34 am    Post subject: Reply with quote
no idea how many it put in of the speed cams as poi loader reported to me 65k of poi`s loaded Laughing
tom tom start 25
Waze
PostPosted: Sat Jan 13, 2007 12:48 pm    Post subject: Re: speed camera updates 12-01-07 Reply with quote
11,217 was the number in the last release. please can you confirm you have a) downloaded the newest version and b) actually told poi loader to use this new version?
tony553
PostPosted: Sat Jan 13, 2007 2:10 pm    Post subject: POI download problem i3 Reply with quote
Laughing I have rectified fault,Thanks. Obviously a computor glitch! Deleted the old PGPS files from the desktop and installed new,now every thing works perfect again.
22.051 (01 May 24)
