Newsletter
Pocket GPS World :: View topic - iGO 2006 review
iGO 2006 review
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
maljay48
PostPosted: Wed Aug 02, 2006 11:49 pm    Post subject: Editing Philipa Reply with quote
No, that wasn't an exact copy, I just did a quick cut and paste job in wordpad. I have checked and double checked the syntax, but every time I transfer the modified file back to Igo, it just doesn't show up in the languages screen, transfer the original back and Philipa is back in all her glory!!! I actually edit the file in Excel and save it as a csv with no formatting, what do you guys do?
Volvo V60 Sat Nav (Garmin?)
Co-Pilot 9.5 on OnePlus1 and Nexus 7
FuzzyDuck
PostPosted: Thu Aug 03, 2006 1:17 am    Post subject: Reply with quote
Hi Mal,
I too struggled to get the edited voice/commands working on my Mio C510, but after re-reading the posts again, I realised that it was zipping up of the folders that was the problem and not my editing!
I had used Winzip 9, right-clicked on the Phillipa zip file and chosen "extract to folder v_eng_uk_f1". Inside this folder were the audio and config folders & files that I played with...
My mistake came when I zipped up the folder again. I simply zipped up the v_eng_uk_f1 folder to "v_eng_uk_f1.zip" - WRONG!!! This puts the audio and config folders a level deeper than they should be! 8O
I should have highlighted the audio folder, config folder, flag_gbr.bmp and info.ini and zipped them up (then renamed the file to v_eng_uk_f1.zip)
As soon as I did this Voila! It worked! :D I ended up leaving Philippa in place, and creating "Fran" as v_eng_uk_f2.zip -- after amending the info.ini file too :D I now have 2 ladies working for me -- one that works and another that almost works
...I'm now working on making Fran very bossy -- I'd like to change "Route Recalculation" to "I TOLD YOU WHERE TO GO AND YOU JUST IGNORE ME, TYPICAL!" Wink
Hope that helps!
FuzzyDuck
Proud owner of:
Mio C620t (the new baby) and a Mio C510e
maljay48
PostPosted: Thu Aug 03, 2006 8:47 am    Post subject: Reply with quote
Thanks Fuzzy
I will have another bash tonight and see how I get on.
Mal J.
linknet
PostPosted: Thu Aug 03, 2006 9:51 am    Post subject: Re: Editing Philipa Reply with quote
That's the problem. Excel will change the syntax even if you save it without formatting. Use a simple text editor, Notepad works fine. I'm sure you'll know how to do this but here it is anyway - Right Click, Open With, Choose Program, Notepad - then just Save, not Save As - since you may end up with a .txt extension.
Regards
Roger
fable
PostPosted: Thu Aug 03, 2006 9:47 pm    Post subject: Reply with quote
FuzzyDuck wrote:
Hi Drogg,
Have you had any luck with creating .OGG audio files? A couple of people in the Mio forum have said that they haven't been able to create compatible .ogg files as yet... if you've found an editor that gets the format right, I'd love to give it a go :D
Edit in wav and convert to ogg with oggenc2.
maljay48
PostPosted: Thu Aug 03, 2006 10:48 pm    Post subject: Editing Reply with quote
Fuzzy, Roger
You were both right, not only had I cocked up the zipping but excel was also a problem too. Philippa now does as she's told!! Wish the wife did!!
I think I might have a dabble with the colour schemes now. I don't know what you guys think, but I'm not keen on any of the colour schemes, not enough contrast between the route marking and the road colours for my liking. That was one of the few things that I liked about Co-Pilot, it was relatively easy to set the colours exactly how you wanted them. Shame about the bugs!!
thanks for your help
mikeycrawford
PostPosted: Thu Aug 10, 2006 3:43 pm    Post subject: Reply with quote
I second AnarchyUK's call for the amended .zip file to be uploaded somewhere. I tried making the changes suggested, and only succeeded in killing the voice, and making the IGO run at a snails pace.
TIA
Mike
JesusPassion
PostPosted: Fri Aug 18, 2006 5:37 pm    Post subject: Reply with quote
Can some of the experts explain in detail how to interpret the code in commands.csv?? I would like to modify the announcements for The Netherlands as people are complaining about this.
It would be very nice and helpfull if some of you experts would like to do this.
linknet
PostPosted: Fri Aug 18, 2006 7:58 pm    Post subject: Reply with quote
There is no definitive guide for modifying these files. Most of the modifications were to small sections of the files and were by trial and error. To write a detailed guide one would need to understand the full syntax of the files which I don't think anyone outside of the iGO team does. If you read pages 2 and 3 of this posting you should find enough information to carry out some simple modifications but that, I'm afraid, is as far as it goes.
Regards
Roger
JesusPassion
PostPosted: Fri Aug 18, 2006 10:10 pm    Post subject: Reply with quote
Regards
Roger
Thanks.
I will try to modify by trial and error.
Btw. Is user 'fable'not from iGo??
linknet
PostPosted: Fri Aug 18, 2006 11:36 pm    Post subject: Reply with quote
Yes, Fable is from iGO. Why do you ask ??
Regards
Roger
JesusPassion
PostPosted: Fri Aug 18, 2006 11:44 pm    Post subject: Reply with quote
Regards
Roger
He should be able to give detail info about the commands.csv file, I thought.
linknet
PostPosted: Fri Aug 18, 2006 11:51 pm    Post subject: Reply with quote
JesusPassion wrote:
Regards
Roger
Then you would need to put that question directly to the developers, you know where Wink
Roger
JesusPassion
PostPosted: Mon Aug 21, 2006 1:59 pm    Post subject: Reply with quote
Hi all,
Who can give me a whole modified commands.csv which I can use in The Netherlands??
Thnx in adv.
Appletom
PostPosted: Sun Feb 04, 2007 1:54 pm    Post subject: Reply with quote
I'm a brand new Mio 310x owner (my first GPS) and I wanted to pop in here and say "Thank You!" for a great forum. I plan on slowly trying to modify my files to eliminate the last verbal turn instruction and a few other things.
It appears there are a large number of knowledgeable and helpful people here at Pocket GPS World, and I am sure I will be browsing your forums with regularity, taking more than I contribute, so I wanted to say hello, thank you, and give a loud "WOW" to the site.
Any advice for someone before he starts making changes to files? I'm sure I will make many errors in the beginning, probably kill the system requiring a complete reload of the software, but it will be fun.
Thanks again from El Paso, Texas
Page 5 of 8
Version 2.1 by Nuke Cops İ 2003 http://www.nukecops.com
20.053 (18 May 22)
İ Terms & Privacy
