Pocket GPS World :: View topic - speed cam
speed cam
richardporter
PostPosted: Sun Apr 02, 2006 11:05 pm    Post subject: speed cam Reply with quote
ok, please help me.
i think i am going mad with this.
i have followed every detail on transfering the database, i really mean every detail and not only once but about 10 times now.
each time it transfers but where the hell do they go after that, its not in "my poi" or active poi.
please help i feel this is so easy but i must be missing something.
cheers
rich
PostPosted: Mon Apr 03, 2006 8:14 pm    Post subject: Reply with quote
Have you followed the guide here which I updated this morning?
richardporter
PostPosted: Tue Apr 04, 2006 9:10 pm    Post subject: speed cam database Reply with quote
i followed it to the letter, the only thing is when i open the asc file in poi editor it stays as a asc file, i have to save it in pio editor to change it as a csv file, but still it does not work, i feel really stupid but this is really starting to hack me off,
Tim Buxton
PostPosted: Tue Apr 04, 2006 9:16 pm    Post subject: Reply with quote
What do you mean, you have to change it in POIEditor to a .csv? Navman's POIEditor reads .asc files and they transfer directly to the device from it.
Tim
PostPosted: Tue Apr 04, 2006 9:17 pm    Post subject: Re: speed cam database Reply with quote
I specifically updated the guide to reflect the fact that Navman now use .asc files, much easier and no editing required.
richardporter
PostPosted: Tue Apr 04, 2006 9:24 pm    Post subject: Reply with quote
ok trying it now, when i downlaod it is opens it in notepad, is that ok
PostPosted: Tue Apr 04, 2006 9:27 pm    Post subject: Reply with quote
Download, extract and then start SmartST and follow the procedure. DON'T open the .asc files in anything, no need!
richardporter
PostPosted: Tue Apr 04, 2006 9:33 pm    Post subject: Reply with quote
right this may be the problem. can i get round this problem as every time i download it opens as a notepad document.
Tim Buxton
PostPosted: Tue Apr 04, 2006 9:36 pm    Post subject: Reply with quote
You have possibly associated .asc files with Notepad, but they shouldn't just open of their own accord. Right-click on an .asc file, then click 'Properties' and see if Notepad shows next to 'Opens with'. If it does, can you change it?
Tim
richardporter
PostPosted: Tue Apr 04, 2006 9:47 pm    Post subject: Reply with quote
well just deleated everything and going to try fresh, i could chage it as well but will just try this,
thanks so far for your help
richardporter
PostPosted: Tue Apr 04, 2006 9:59 pm    Post subject: Reply with quote
ok just to confirm when it says succsessfully downloaded to device, thats it do i u just pull the cable from the bottom and it restarts, then were should i goto on device
richardporter
PostPosted: Tue Apr 04, 2006 10:09 pm    Post subject: Reply with quote
ok still no luck, what am i doing wrong.
i followed all instructions then disconnected device, it bleeped at me then restarted, is that normal
Tim Buxton
You don't need to do anything IF you selected to make the POIs 'Active' and setup audible and visual warnings for them. I also set visibility to maximum. All this can be done from POIEditor.
If you haven't done this, you can do it from Preferences, Safety Alerts, Active POI. You will need to select each POI in turn and ensure Active, Audio warning and Visual Warning, then adjust Distance to POI as required. I use 1/4 mile for cameras.
Tim
richardporter
PostPosted: Tue Apr 04, 2006 10:11 pm    Post subject: Reply with quote
but in my poi`s there is nothing to make active argghhh
Tim Buxton
PostPosted: Tue Apr 04, 2006 10:16 pm    Post subject: Reply with quote
OK connect your iCN to your PC but don't start the Navman Desktop. Use Activesync and explore the device. Look for a directory called MYPOI and tell me where it is (Device or SD card) and the directory structure.
Tim
