Pocket GPS World :: View topic - TomTom 5 Landscape and Portrait Mount
Golfer
PostPosted: Sat Jul 30, 2005 7:11 pm    Post subject: TomTom 5 Landscape and Portrait Mount Reply with quote
Sorry if this has already been covered (I did a search).
But can anyone recommend a good mount that can lock into both a landscape or portrait position depending on which one you want at any time? For example, I would like to lock the mount into landscape poition wiht TomTom5, but switch to portrait mode at other times. If it to lock into position, that would avoid possible slip movement.
Thanks in advance.
nikbedwell
PostPosted: Sat Jul 30, 2005 8:55 pm    Post subject: Reply with quote
This is where I got my mounting equipment from... they produce kits for most iPAQ and XDA models (I use XDAII):
http://www.seidio-europe.com
Golfer
PostPosted: Sat Jul 30, 2005 9:25 pm    Post subject: Reply with quote
Thanks, the mounts look good. I have an ipaq 5550, so I think this is the one I would need
http://www.seidio-europe.com/PhotoGallery.asp?ProductCode=BD%2DSMGF1IP54x
The description talks about a swivel capability, but just to absolutely clarify, does the mount enable the ipaq to be turned 90 degrees from partrait to landscape mode? Also, is there a UK outlet as I need to get one by Wednesday?
Thanks again
flashpaul
PostPosted: Sun Jul 31, 2005 6:15 pm    Post subject: Reply with quote
I can recommend the arkon powered mounts available from morpeth mobiles
on ebay or direct from their website
It doesnt actually lock into landscape mode but you can tighten a screw on the goose neck so it wont move
deesoft
PostPosted: Sun Jul 31, 2005 9:33 pm    Post subject: Rotation Reply with quote
I can recommend the Brodit mounts, they use friction to lock in position. Thar are very well made, they can be bougth from www.handnav.co.uk
. But whether you would get one for Wednesday???
Ipaq hx2750, TTN5, Globalsat 338 GPS, Garmin Nuvi 310D and GTM12, TomTom GO910 and now GO540
God gave us the Integer, the rest was devised by man.
22.051 (01 May 24)
