Golfer Regular Visitor
Joined: 30/08/2002 23:40:01 Posts: 61 Location: United Kingdom
Posted: Sat Jul 30, 2005 7:11 pm Post subject: TomTom 5 Landscape and Portrait Mount |
Sorry if this has already been covered (I did a search).
But can anyone recommend a good mount that can lock into both a landscape or portrait position depending on which one you want at any time? For example, I would like to lock the mount into landscape poition wiht TomTom5, but switch to portrait mode at other times. If it to lock into position, that would avoid possible slip movement.
Thanks in advance. |
nikbedwell Occasional Visitor
Posted: Sat Jul 30, 2005 8:55 pm Post subject: |
This is where I got my mounting equipment from... they produce kits for most iPAQ and XDA models (I use XDAII):
http://www.seidio-europe.com |
Posted: Sat Jul 30, 2005 9:25 pm Post subject: |
nikbedwell wrote: | This is where I got my mounting equipment from... they produce kits for most iPAQ and XDA models (I use XDAII):
Thanks, the mounts look good. I have an ipaq 5550, so I think this is the one I would need
http://www.seidio-europe.com/PhotoGallery.asp?ProductCode=BD%2DSMGF1IP54x
The description talks about a swivel capability, but just to absolutely clarify, does the mount enable the ipaq to be turned 90 degrees from partrait to landscape mode? Also, is there a UK outlet as I need to get one by Wednesday?
Thanks again |
flashpaul Occasional Visitor
Posted: Sun Jul 31, 2005 6:15 pm Post subject: |
I can recommend the arkon powered mounts available from morpeth mobiles
on ebay or direct from their website
It doesnt actually lock into landscape mode but you can tighten a screw on the goose neck so it wont move |
deesoft Regular Visitor
Joined: 14/03/2003 19:10:05 Posts: 138 Location: Warrington, Cheshire, UK
Posted: Sun Jul 31, 2005 9:33 pm Post subject: Rotation |
I can recommend the Brodit mounts, they use friction to lock in position. Thar are very well made, they can be bougth from www.handnav.co.uk
. But whether you would get one for Wednesday???
David _________________ Ipaq hx2750, TTN5, Globalsat 338 GPS, Garmin Nuvi 310D and GTM12, TomTom GO910 and now GO540
God gave us the Integer, the rest was devised by man. |
