Pocket GPS World :: View topic - Connecting Garmin GPS III to laptop...
effzed
PostPosted: Mon Jul 19, 2004 11:55 pm    Post subject: Connecting Garmin GPS III to laptop... Reply with quote
Can anyone help. I have searched the forums but cannot find the answer...
I am thinking about buying a lead from Maplins to connect my rather old Garmin GPS III to my laptop, so that I can track my position using Autoroute 2004. My GPS III is NMEA 0183 v2 compliant.
Do you know if this will work? Has anyone tried it?
thanks
eff
PostPosted: Tue Jul 20, 2004 4:29 am    Post subject: Reply with quote
If your laptop still has a serial connector then this will work without problem.
PostPosted: Tue Jul 20, 2004 9:28 am    Post subject: Reply with quote
I havent used the GPS III but I have connected a Geko, and a GPSMap 76 to my laptop with no problems. The only thing to remember is to check the Protocol, as Garmins do tend to default to the GARMIN protocol not NMEA
Tim Buxton
PostPosted: Tue Jul 20, 2004 1:51 pm    Post subject: Re: Connecting Garmin GPS III to laptop... Reply with quote
thanks
eff
I have connected my GPS 3+, (now sold) and my GPS V to a laptop using the supplied serial cable, and I have also made my own. All you need is a 9 pin male connector and a Garmin 4 pin plug, which you can get from here, some 4 conductor cabel (telephone wire is adequate) and a slodering iron.
If your laptop only has USB ports you can get a dedicated Garmin/USB cable or use the one you're going to make(!) in conjunction with a Serial/USB adapter cable.
Tim
effzed
PostPosted: Tue Jul 20, 2004 5:07 pm    Post subject: thanks Reply with quote
thanks for your responses - you have all answered my question.
bravo
eff
22.052 (08 May 24)
