Pocket GPS World :: View topic - XL Live map freezing
frugalmike2
PostPosted: Thu Sep 26, 2013 6:16 am    Post subject: XL Live map freezing Reply with quote
Hi I wonder if anyone can help with the following, My xl live with hd traffic keeps freezing the map display.
The unit itself does not freeze and the voice directions continue to function, if i then tap the screen the menu appears and then i press done and all is well until the next time which can be minutes or hours away,also deliberately ignoring the directions to create an automatic reroute it does this fine and the map then starts to work once again with no need to touch the unit.
I am running version 8.419 and would prefer not to update this if possible and preferably avoid using the tom tom software, would the factory reset help? and would the hd traffic subscription be affected by this?
This only started happening in the last 2 weeks.
any help appreciated thanks
dhn
PostPosted: Thu Sep 26, 2013 10:23 am    Post subject: Reply with quote
Why your aversion to updating the application and using tomtom software?
Your unit isn't hacked, is it?
frugalmike2
PostPosted: Thu Sep 26, 2013 4:31 pm    Post subject: Reply with quote
My first XL died sometime ago so i purchased this one secondhand and it still had 9 months traffic subscription, when it got down to about a month remaining I renewed the subscription and somehow whilst connecting to tt home I managed to lose what i already had, I am guessing because tomtom home thought it was my old unit? also I tried the later software on my old xl but prefer to use this one.
any ideas on the problem i am having?
dhn
PostPosted: Thu Sep 26, 2013 5:35 pm    Post subject: Reply with quote
Well, you should not be using the same email address for this unit than the last one. Normally, subscriptions are not transferable between devices but you may get a sympathetic CS agent:
United Kingdom
0845 161 0009
or 020 7387 5444
Monday-Friday:
9:00 am to 5:30 pm BST
frugalmike2
PostPosted: Thu Sep 26, 2013 6:49 pm    Post subject: Reply with quote
United Kingdom
0845 161 0009
or 020 7387 5444
Monday-Friday:
It is a different unit ,different email address,the unit came with 9 months remaining traffic the problem came when i tried to renew as i was using tt home on the original computer,the traffic subscription is live working and runs til august 2014.
The problem is the map freezing.
PostPosted: Thu Sep 26, 2013 8:15 pm    Post subject: Reply with quote
That shouldn't be an issue... So long as you have different account names for each device, you can update/manage as many different TomToms as you like on the same PC.
I update a GO720, an XL Live, a GO 940 and a GO950 all with the same copy of Home on a single PC.
For the freezing issue...
Are you using recent map version with the old software version? That can cause problems.
As it looks like you've previously tried the more recent software, but were able to roll back to the older version, then it sounds like you will be capable of putting the new software back on for a while to see if the freezing problem goes away?
At least then you'll know where the issue lies.
Also, do you have a large number of POIs enabled to show on the map? Try turning them all off for awhile to see if that improves matters.
"Settling in nicely" ;-)
frugalmike2
PostPosted: Tue Oct 08, 2013 7:17 pm    Post subject: Reply with quote
All sorted now I was advised on another forum to run the tomtom clear flash tool 3 times and all has been well for several days now Very Happy
21.021 (01 Feb 23)
