DaveNN Lifetime Member
Posted: Fri Feb 25, 2011 2:45 pm Post subject: 750 live common routes. |
when setting up the TT I noticed an option to have specific routes/addresses (not favourites) loaded for easy access.
I ignored that option, thinking that I could do it after.
How, excepting a factory reset, can I access that screen pls?
scrub this..did a factory reset...pnly took a few minutes... _________________ Jaguar XF R Sport AWD
Onboard nav with live stuff, weather, news and stuff.
NextBase Duo DashCam
Running Cameralert via Samsung S7 Edge |
IanS100 Frequent Visitor
Posted: Fri Feb 25, 2011 3:45 pm Post subject: |
I think this is the 'frequent destinations' menu but, like you I ignored the option when first used & I've never seen it since |
Posted: Fri Feb 25, 2011 3:52 pm Post subject: |
From the User Guide (Pg 9)
Frequent destinations
If you often make trips to the same destinations, you can set your device to
ask if you want to plan a route to one of these locations every time the device
starts. This is faster than planning a route in the normal way.
To select a new destination, tap Start-up preferences in the Preferences menu
then select Ask for a destination. You are asked if you want to select a new
destination and you then need to answer a few questions about the location. |
Posted: Fri Feb 25, 2011 7:49 pm Post subject: |
IanS100 wrote: | From the User Guide (Pg 9)
Cheers,
I did a factory reset & all's well... _________________ Jaguar XF R Sport AWD
