Pocket GPS World :: View topic - 750 live common routes.
DaveNN
PostPosted: Fri Feb 25, 2011 2:45 pm    Post subject: 750 live common routes. Reply with quote
when setting up the TT I noticed an option to have specific routes/addresses (not favourites) loaded for easy access.
I ignored that option, thinking that I could do it after.
How, excepting a factory reset, can I access that screen pls?
scrub this..did a factory reset...pnly took a few minutes...
Jaguar XF R Sport AWD
Onboard nav with live stuff, weather, news and stuff.
NextBase Duo DashCam
Running Cameralert via Samsung S7 Edge
IanS100
PostPosted: Fri Feb 25, 2011 3:45 pm    Post subject: Reply with quote
I think this is the 'frequent destinations' menu but, like you I ignored the option when first used & I've never seen it since
IanS100
PostPosted: Fri Feb 25, 2011 3:52 pm    Post subject: Reply with quote
From the User Guide (Pg 9)
Frequent destinations
If you often make trips to the same destinations, you can set your device to
ask if you want to plan a route to one of these locations every time the device
starts. This is faster than planning a route in the normal way.
To select a new destination, tap Start-up preferences in the Preferences menu
then select Ask for a destination. You are asked if you want to select a new
destination and you then need to answer a few questions about the location.
DaveNN
PostPosted: Fri Feb 25, 2011 7:49 pm    Post subject: Reply with quote
Cheers,
I did a factory reset & all's well...
