Pocket GPS World :: View topic - Mini-USB Cable with all 5 Pins Wired ?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Traffic Message Channel (TMC)
philip4242
PostPosted: Tue Jul 21, 2009 12:20 pm    Post subject: Mini-USB Cable with all 5 Pins Wired ? Reply with quote
I have a MIO P550 PDA and a Garmin TMC receiver with a Mini-USB plug.
The 2 units communicate OK using the original cables, and the receiver works well.
However, I want to incorporate the TMC receiver into the amplified car holder/charger I already have, but don't want to destroy the original cables.
To enable the PDA to recognise the TMC receiver, I need a Mini-USB cable which has all 5 pins wired OR has Pin 4 connected to Pin 5 (or Pin X connected to Pin 4, depending on how the pins are defined - I've seen both ways specified, during my research !)
The problem is that most Mini-USB cables have only the 4 'normal' pins (+V, DATA+, DATA-, -VE) wired, leaving the 5th pin not connected.
Does anyone know of a supplier of a suitable cable ?
(The connector at the other end of the cable is irrelevant, as I'll be soldering directly to the TMC circuit board.)
I've already tried 'modifying' a connector (by bridging the connections with a minute amount of solder), which resulted in much melting of plastic - and I'm not an amateur !
Also, all the 'loose' connectors I've seen do not have the required pin brought out.
Getting older and more senile by the minute !
Philip
Pocketgps
PostPosted: Tue Jul 21, 2009 3:47 pm    Post subject: Reply with quote
You could make a cable up yourself using the correct plug from Maplin.
Have a look HERE (opens in a new window).
philip4242
PostPosted: Tue Jul 21, 2009 4:29 pm    Post subject: Reply with quote
It may well say '5-pin mini USB plug' in the description (which it IS), but only 4 of the pins have solder pads, and the 5th pin is not accessible at any point where it could sensibly be soldered to the adjacent pin - Guess how I found this out ?!
As I say, 'all the 'loose' connectors I've seen do not have the required pin brought out.' - but thanks for the suggestion.
Any other thoughts, anyone ?
Philip
Pocketgps
PostPosted: Tue Jul 21, 2009 8:53 pm    Post subject: Reply with quote
Did not realise that the plugs had only 4 solder tabs.
This web site HERE gives some info on pin outs.
And I thought that they were all the same - silly me Embarassed
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Traffic Message Channel (TMC) All times are GMT + 1 Hour
