linknet Frequent Visitor
Posted: Fri Feb 20, 2009 11:40 am Post subject: |
Looks like a simplified version, let's hope not.
linknet |
mihok Occasional Visitor
Posted: Fri Feb 20, 2009 12:49 pm Post subject: |
not from the shop
iGo_8.3.2.64873_07.2008_Euro_Maps__FR_US_UK_Lang_Only
linknet wrote: | mihok wrote: | I have this version: iGO8 PNA Version 8.3.2.64873 dated 13th November 2008
what you thing, why did I ask you?
Then it's the same answer:
You must be using the wrong data.zip for the version of iGO8 that you are using. With the correct data.zip you will not get that error.
Where did you purchase the iGO8 software ?
linknet | |
Posted: Fri Feb 20, 2009 12:59 pm Post subject: |
mihok wrote: | not from the shop |
Then I'm afraid I can't help.
linknet |
Posted: Fri Feb 20, 2009 1:48 pm Post subject: |
all right
tahnx again
[quote="linknet"][quote="mihok"]not from the shop [/quote]
linknet[/quote] |
Posted: Fri Feb 20, 2009 4:08 pm Post subject: |
I'll go buy it
because I can't live without tahat skin
linknet[/quote] |
fr0d0 Occasional Visitor
Posted: Sat Feb 21, 2009 8:02 pm Post subject: |
Tested for 2 days linknet and on the same route that I noticed the fault occurring and no sign of it any more. Hopefully you cracked it ;) |
Posted: Sat Feb 21, 2009 8:29 pm Post subject: |
fr0d0 wrote: | Tested for 2 days linknet and on the same route that I noticed the fault occurring and no sign of it any more. Hopefully you cracked it ;) |
Thanks for the feedback, I'll release it as a new version shortly.
Regards
linknet |
floepie Occasional Visitor
Posted: Mon Feb 23, 2009 6:23 am Post subject: |
Linknet, Yours is the only skin that simply won't show up on my device. I have a VGA device. I have the right version you specify, vga=1, highres=1, with resolution directory of 320_240 all entered in their respective sections within the sys.txt. THere are no errors - it simply doesn't appear in the list of available skins. Are there any known entries in the SYS that might conflict with your skin? Thanks.... |
Posted: Mon Feb 23, 2009 9:26 am Post subject: |
floepie wrote: | Linknet, Yours is the only skin that simply won't show up on my device. I have a VGA device. I have the right version you specify, vga=1, highres=1, with resolution directory of 320_240 all entered in their respective sections within the sys.txt. THere are no errors - it simply doesn't appear in the list of available skins. Are there any known entries in the SYS that might conflict with your skin? Thanks.... |
Not that I'm aware of, the only entry in the skin is:
supported_resolutions="240_320,320_240"
in the info.ini file.
linknet |
Posted: Mon Feb 23, 2009 7:42 pm Post subject: |
OK, figured it out. I have a device whose resolution is 800x480. For whatever reason, your skin requires me to modify the screen_x and screen_y values to the values the skin would expect, i.e. 640x480 for VGA.
Thus far, I have been able to keep the values at 800 and 480, respectively, while simply modifying the resolution_dir=xxx_xxx to select the resolution the skin supports. That seemed to work for every other skin except yours.
Odd, eh? |
saphir78 Occasional Visitor
Posted: Tue Feb 24, 2009 12:39 pm Post subject: |
Hello Linknet,
First i would like to say you THANK YOU.. is the best skin for Igo8.
i have just one question : can i use this skin with my samsung I900 Omnia ?
And if not there are any chance to have Resolution 400_240 for omnia ?
I hope yes.
thanks for your reply |
Posted: Tue Feb 24, 2009 12:57 pm Post subject: |
saphir78 wrote: | Hello Linknet,
I'm afraid not.
linknet |
Posted: Tue Feb 24, 2009 2:09 pm Post subject: |
Oh nooooo ...
and do you think that using WVGAFIX3 to change resolution of my omnia in 240x320 i will can use your skin ??
WVGAFIX3 is a little soft to change resolution.
Thanks |
Posted: Tue Feb 24, 2009 2:44 pm Post subject: |
saphir78 wrote: | Oh nooooo ...
Thanks |
I don't know, why not just try it ?
linknet |
voyo Occasional Visitor
Posted: Wed Feb 25, 2009 6:18 pm Post subject: FFUIERROR: Parse error [layer expected] |
Hello all,
as I'm not an advanced user on Igo I have an question.
I own the FS Pocket loox560 with windows mobile 5 and a VGA screen
IGo 8 version 8.0.0.31442
after applying the Igo 8 Ultra Skin 6.0.10 i have got this message at star
my SYS.TXT is as follows
[folders]
app="%SDCARD%/iGO8"
[interface]
maxzoom2d=6000000
show_exit=1
where can be the error?
I wish to run it at VGA resolution
Thank you
voyo |
