Pocket GPS World :: View topic - iGO8 Ultra Skin 6.0.22
Goto page Previous  1, 2, 3 ... 15, 16, 17 ... 33, 34, 35  Next
linknet
PostPosted: Fri Feb 20, 2009 11:40 am    Post subject: Reply with quote
Dusha wrote:
some Amigo screens found on the Net:
http://gps.favoriteam.sk/archiv/igo-amigo.html
Looks like a simplified version, let's hope not. Wink
linknet
mihok
PostPosted: Fri Feb 20, 2009 12:49 pm    Post subject: Reply with quote
not from the shop
Embarassed
iGo_8.3.2.64873_07.2008_Euro_Maps__FR_US_UK_Lang_Only
linknet wrote:
mihok wrote:
I have this version: iGO8 PNA Version 8.3.2.64873 dated 13th November 2008
what you thing, why did I ask you? Sad
Then it's the same answer:
You must be using the wrong data.zip for the version of iGO8 that you are using. With the correct data.zip you will not get that error.
Where did you purchase the iGO8 software ?
linknet
Embarassed Embarassed
linknet
PostPosted: Fri Feb 20, 2009 12:59 pm    Post subject: Reply with quote
mihok wrote:
not from the shop Embarassed
Then I'm afraid I can't help. Crying or Very sad
linknet
mihok
PostPosted: Fri Feb 20, 2009 1:48 pm    Post subject: Reply with quote
all right
tahnx again
Embarassed
[quote="linknet"][quote="mihok"]not from the shop Embarassed[/quote]
linknet[/quote]
mihok
PostPosted: Fri Feb 20, 2009 4:08 pm    Post subject: Reply with quote
I'll go buy it
because I can't live without tahat skin
Smile
linknet[/quote]
fr0d0
PostPosted: Sat Feb 21, 2009 8:02 pm    Post subject: Reply with quote
Tested for 2 days linknet and on the same route that I noticed the fault occurring and no sign of it any more. Hopefully you cracked it ;)
linknet
PostPosted: Sat Feb 21, 2009 8:29 pm    Post subject: Reply with quote
Thanks for the feedback, I'll release it as a new version shortly.
Regards
linknet
floepie
PostPosted: Mon Feb 23, 2009 6:23 am    Post subject: Reply with quote
Linknet, Yours is the only skin that simply won't show up on my device. I have a VGA device. I have the right version you specify, vga=1, highres=1, with resolution directory of 320_240 all entered in their respective sections within the sys.txt. THere are no errors - it simply doesn't appear in the list of available skins. Are there any known entries in the SYS that might conflict with your skin? Thanks....
linknet
PostPosted: Mon Feb 23, 2009 9:26 am    Post subject: Reply with quote
Not that I'm aware of, the only entry in the skin is:
supported_resolutions="240_320,320_240"
in the info.ini file.
linknet
floepie
PostPosted: Mon Feb 23, 2009 7:42 pm    Post subject: Reply with quote
OK, figured it out. I have a device whose resolution is 800x480. For whatever reason, your skin requires me to modify the screen_x and screen_y values to the values the skin would expect, i.e. 640x480 for VGA.
Thus far, I have been able to keep the values at 800 and 480, respectively, while simply modifying the resolution_dir=xxx_xxx to select the resolution the skin supports. That seemed to work for every other skin except yours.
Odd, eh?
saphir78
PostPosted: Tue Feb 24, 2009 12:39 pm    Post subject: Reply with quote
Hello Linknet,
First i would like to say you THANK YOU.. is the best skin for Igo8.
i have just one question : can i use this skin with my samsung I900 Omnia ?
And if not there are any chance to have Resolution 400_240 for omnia ?
I hope yes.
thanks for your reply
linknet
PostPosted: Tue Feb 24, 2009 12:57 pm    Post subject: Reply with quote
saphir78 wrote:
Hello Linknet,
I'm afraid not. Crying or Very sad
linknet
saphir78
PostPosted: Tue Feb 24, 2009 2:09 pm    Post subject: Reply with quote
Oh nooooo ...
and do you think that using WVGAFIX3 to change resolution of my omnia in 240x320 i will can use your skin ??
WVGAFIX3 is a little soft to change resolution.
linknet
PostPosted: Tue Feb 24, 2009 2:44 pm    Post subject: Reply with quote
saphir78 wrote:
Oh nooooo ...
I don't know, why not just try it ? Wink
linknet
voyo
PostPosted: Wed Feb 25, 2009 6:18 pm    Post subject: FFUIERROR: Parse error [layer expected] Reply with quote
Hello all,
as I'm not an advanced user on Igo I have an question.
I own the FS Pocket loox560 with windows mobile 5 and a VGA screen
IGo 8 version 8.0.0.31442
after applying the Igo 8 Ultra Skin 6.0.10 i have got this message at star
my SYS.TXT is as follows
[folders]
app="%SDCARD%/iGO8"
[interface]
maxzoom2d=6000000
show_exit=1
where can be the error?
I wish to run it at VGA resolution
Thank you
voyo
Page 16 of 35
