Pocket GPS World :: View topic - Where can I get more maps?
JessopSmythe
PostPosted: Mon Sep 25, 2006 12:03 am    Post subject: Where can I get more maps? Reply with quote
I'm running MM v5 OS and I'm looking for maps of Corfu. The OS versions of MM don't allow you to scan and calibrate your own maps so it seems as if I have two options.
1) Buy MM Europe which will allow me to scan and calibrate
2) Try and locate calibrated maps of the Corfu area at a sensible price.
Any suggestions as to where I can get the maps at a sensible price?
MrT
PostPosted: Mon Sep 25, 2006 4:19 pm    Post subject: Reply with quote
You do not need to buy MM Europe or MM USA and these products (not tried Europe) will work with you serial but just won't let you use OS maps. They will install to a different directory so you can have both on your PC at the same time. I have used this to calibrate high res aerial photography. These maps will then work with the OS version.
G1LIW
PostPosted: Tue Oct 30, 2007 1:47 am    Post subject: Reply with quote
OK, may be the time of night, but Mr T, you just confused the wotsit out of me!
Are you saying that MM v5 UK CAN use maps from other sources - even scanned maps? if so, can you type up a "how to" guide for us, please?
JasonMM
PostPosted: Tue Oct 30, 2007 11:27 am    Post subject: Reply with quote
No, you can only scan and calibrate maps using the Memory-Map European Edition which you can download from www.memory-map.co.uk and activate it with your existing OS Licence details
mhb
PostPosted: Wed Oct 31, 2007 5:51 pm    Post subject: Reply with quote
Just to clarify further, I believe that the scanned in maps from MM European Edition, can then be used in MM OS?
robertn
PostPosted: Thu Nov 01, 2007 2:16 am    Post subject: Reply with quote
Before you go ahead, consider the problem with self calibrated maps - how much work involved in doing it, how accurate will it be, and if it is wrong, can you correct it in the feild.
I played around with doing it and gave up and solved the problem with money - maybe you are more accruate and patient than me.
21.014 (25 Jan 23)
