Pocket GPS World :: View topic - I3 keeps losing satallite signal
JohnWB
PostPosted: Thu Aug 02, 2007 8:43 am    Post subject: I3 keeps losing satallite signal Reply with quote
We have a Garmin i3 which has worked fine for the last year. However the last 2 times we have used it has started loosing the satallite signal while driving along. Does anyone have any idea why this should have started happening. The unit has been running on batteries and in the same car (Peugeot 206)
PaulB2005
PostPosted: Thu Aug 02, 2007 8:50 am    Post subject: Reply with quote
Peugeot 206 - does this have the Anthermic (blue-ish heat reflective) windscreen?
When you loose the signal is it in places where there was no problem before?
Did you let it get a fix on the satellites before you started your journey?
JohnWB
PostPosted: Thu Aug 02, 2007 11:28 am    Post subject: Reply with quote
Not as far as I know, but it was OK befor in any case
It is losing the signal on places such as the main dual carrdgeway when it has always been fine before
It had a fix before we set off
PaulB2005
PostPosted: Thu Aug 02, 2007 2:39 pm    Post subject: Reply with quote
Hmm. Possibly a fault in the unit. Did it coincide with bumps or pot holes or corners at all??
Has the unit been dropped recently?
Does it say (voice) "Lost Satellite Reception"?
PowerLee
PostPosted: Thu Aug 02, 2007 7:35 pm    Post subject: Reply with quote
A lot of the higher spec 206s do have an anthermic windscreen according to the wonderful Pug parts cd rom.
For you 206 hatchback owners out there you have a choice of 6 different windscreens to pick from, 2 of them normal & the other 4 anthermic.
Garmin I3
V9 maps on a 2GB card & 2.7 firmware
sunstrip_steve
PostPosted: Thu Aug 02, 2007 9:01 pm    Post subject: Reply with quote
What firmware is it running? Have you upgraded it. I found that on 3.4 mind randomly says 'lost satellite reception', when i say randomly, normally when i go off the planned route, then it immediately says 'recalculating'.
but it still works ok
JohnWB
PostPosted: Fri Aug 03, 2007 9:42 am    Post subject: Reply with quote
No bumps or pot holes
Not dropped at all
It does say "Lost Satellite Reception"
Firmware 2.7 (origional & the best I think)
PaulB2005
PostPosted: Mon Aug 06, 2007 5:37 pm    Post subject: Reply with quote
Try it on the ciggy power lead and see what happens.
