Pocket GPS World :: View topic - QUEST 1 - NO SATELLITES?
GPSHonda
PostPosted: Sun Apr 02, 2006 7:38 pm    Post subject: QUEST 1 - NO SATELLITES? Reply with quote
I wonder if anyway can help me out..
I've had my Quest a few weeks, I know my round gps - I had various versions for years (emap, SPIII, 2610, 2620, Quest), and all the firmware & maps are up to date.
Yesterday, the unit repeatedly gave the 'POOR SATELLITE RECEIPT' (or whatever the exact words are) message, at first I thought nothing of it, as occasionally they all loss the sats, but after this happened a number of times whilst I was navigating the unit became unusable, because it was taking ages to re-find the sats - fortunately a mate came to my rescue wit his SPIII.
I will add at this point that the unit was running on a fully charged internal battery, mounted onto a bike with a clear unhindered view of the very clear sky, the gps setting is set to ‘normal’.
After lunch, the Quest started to navigate, but within 10 miles 'POOR SATELLITE RECEIPT' was on the screen again, but this time no sats for well over an hour!!!
I got home, switched to GPS INFO and watched, nothing! Then 8 or more sats appeared, then all together they all vanish, not reducing in strength, not going off one at a time, but rather all together like a switch has been turn off.
Today, out in the car with GPS INFO on the screen for hours - the exact same problems repeated themselves - 8+ sats then none, like a switch, then after a while they all reappear at once,
I can't stress enough that this is NOT the usual occurrences of sats fading in & out of strength or viewability by the unit.
I'm tending to lean towards a loose connection or dry joint, as at this moment the unit is fixed inside my lounge window, showing 5 or so sats (as I would expect with it limited 'view' of the sky). The unit has remained working, untouched for a couple of hours. BUT of course there is no vibration in its present situ.
Any ideas?
ta
Peter
GPSHonda
PostPosted: Sun Apr 02, 2006 8:25 pm    Post subject: Reply with quote
However, knocking the unit in a left/right motion seems to recreate the problem.
oddsock
PostPosted: Sun Apr 02, 2006 9:32 pm    Post subject: Reply with quote
No guarentee ?
TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest
dandywarhol
PostPosted: Mon Apr 03, 2006 3:44 pm    Post subject: Reply with quote
I've had exactly the same problem on the last 2 occasions with my quest 1 and yesterday (2nd April) was one of them 8O
Garmin Quest|Ram Mount|Yamaha TDM900
At the cutting edge of technophobia
GPSHonda
PostPosted: Tue Apr 04, 2006 9:46 am    Post subject: Reply with quote
I spoke with Garmin.
Unit going back for investigation - I let you know the outcome.
GPSHonda
PostPosted: Mon Apr 10, 2006 12:37 pm    Post subject: Reply with quote
Excellent service from Garmin.
Sent - Monday, Back - Friday.
Unit replaced.
Kritou
PostPosted: Mon Apr 10, 2006 6:19 pm    Post subject: Reply with quote
Unit replaced.
So Garmin have a stock of Quests - wonder if and when they will sell them off?
21.054 (24 May 23)
