davjack Occasional Visitor
Posted: Sun Jun 05, 2005 2:17 pm Post subject: active sync |
can any one help my medion250 will no longer make a sync with my pc tried re installing active sync but just says no partnership how do i reset my pda so i can set up a new partnership with pc |
lbendlin Pocket GPS Staff
Posted: Sun Jun 05, 2005 2:26 pm Post subject: |
What happens when you insert the PPC into the cradle - does the ActiveSync Window pop up? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Mon Jun 06, 2005 9:30 pm Post subject: |
no nothing happens used to pop up |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Tue Jun 07, 2005 12:01 am Post subject: |
Re-start your main PC, then turn ON your PDA, then place it in it's cradle, now click on My Computer (main PC), then click on Mobile Device, you should be able to explore it that way, if you can, copy any small file of your main pc (any size between 1kb to 20kb) then paste it to any folder on your PDA, then delete it on your PDA, then close the explore window and then remove your PDA from it's cradle, then put it back into the cradle, it should now open ActiveSync, if it doesn't then try the above again, this normally forces ActiveSync to work.
I know this all sounds a bit peculiar, but it has worked for me several times. |
