Pocket GPS World :: View topic - active sync
active sync
davjack
PostPosted: Sun Jun 05, 2005 2:17 pm    Post subject: active sync Reply with quote
can any one help my medion250 will no longer make a sync with my pc tried re installing active sync but just says no partnership how do i reset my pda so i can set up a new partnership with pc
lbendlin
PostPosted: Sun Jun 05, 2005 2:26 pm    Post subject: Reply with quote
What happens when you insert the PPC into the cradle - does the ActiveSync Window pop up?
Lutz
TomTom/TeleAtlas NAVTEQ
davjack
PostPosted: Mon Jun 06, 2005 9:30 pm    Post subject: Reply with quote
no nothing happens used to pop up
Pocketgps
PostPosted: Tue Jun 07, 2005 12:01 am    Post subject: Reply with quote
Re-start your main PC, then turn ON your PDA, then place it in it's cradle, now click on My Computer (main PC), then click on Mobile Device, you should be able to explore it that way, if you can, copy any small file of your main pc (any size between 1kb to 20kb) then paste it to any folder on your PDA, then delete it on your PDA, then close the explore window and then remove your PDA from it's cradle, then put it back into the cradle, it should now open ActiveSync, if it doesn't then try the above again, this normally forces ActiveSync to work.
I know this all sounds a bit peculiar, but it has worked for me several times.
22.044 (24 Apr 24)
