Pocket GPS World :: View topic - Cassiopeia GPS
Cassiopeia GPS
Tomlewis007
PostPosted: Fri Sep 24, 2004 4:35 pm    Post subject: Cassiopeia GPS Reply with quote
Hello all Smile
I might be getting my hands on a cassiopeia for free (it needs a new battery) i wanted to see if i could make my self up a cheap-ish GPS system with the safty camera POI on it ?
Can i get voice guide on the cassiopeia ?
any feedback would be great.
thanks
-Tom
PostPosted: Fri Sep 24, 2004 4:38 pm    Post subject: Reply with quote
Which Casio ?
Tomlewis007
PostPosted: Mon Sep 27, 2004 2:03 pm    Post subject: Reply with quote
I dont know exactly but its one of the square ones, not one of the really old flip style ones. I think its an E something with a 200Mhz CPU ?
I will try to get some more info.
thanks
-TOm
PostPosted: Mon Sep 27, 2004 2:20 pm    Post subject: Reply with quote
Goto http://www.pocketgpsworld.com/compareomatic/index.php?TempID=8 and take a look by adding the Casio's and you should see an image of each one and that should tell you which one you have.
There's very limited support now for the older Casio's e.g. EM500, E105, E115, E125. If it's an E200 then it won't be bad, and you should get voice guidance working.
The E125 and below will run TTN2 and below but I'm not sure about TTN3.
alix776
PostPosted: Tue Sep 28, 2004 7:07 pm    Post subject: Reply with quote
it might have the same problems as hp jornada 568 when runing make sure you dissale the show poi (points of interest) if your runnig the 2002 version of pocket pc then it should run ok also make sure the receaive all incoming beams is turned off to youll probbably need a wired gps using a y cable and i think a compact flash card for the maps hope this helps you
device Lumia 950 xl
Tomlewis007
PostPosted: Wed Sep 29, 2004 4:15 pm    Post subject: Reply with quote
Thats great thanks all.
On a side note totally off GPS can the version of Pocket PC be upgraded on PDA's ?
thanks again all
-Tom
alix776
PostPosted: Wed Sep 29, 2004 5:43 pm    Post subject: Reply with quote
if its running ppc 2002 then yes if not i dont think so
device Lumia 950 xl
PostPosted: Wed Sep 29, 2004 9:30 pm    Post subject: Reply with quote
It would also have to be a manufacturer CD upgrade and I don't believe Casio provided any customised upgrades for their PPC's.
Tomlewis007
PostPosted: Tue Oct 05, 2004 9:23 am    Post subject: Reply with quote
Im guessing this is bad news, I now have the Cassiopeia its an E-105 and its running Windows CE
Im guessing i cant get any GPS software for this as most say Pocket PC ?
thanks
PostPosted: Wed Oct 06, 2004 8:42 am    Post subject: Reply with quote
It may work, but remember it's a reduced processor speed and lower memory (32mb). You will need to find applications that support the MIPS processor rather than ARM which is the standard now.
alix776
PostPosted: Wed Oct 06, 2004 9:53 am    Post subject: Reply with quote
i think navigator 1 MAY work with win ce
device Lumia 950 xl
21.014 (25 Jan 23)
