scrw Occasional Visitor
Posted: Tue Mar 08, 2005 8:41 am Post subject: |
finally fixed it :D
tried the BT tools from here again - http://www.bluetooth.jazztel.es/ this time when I bonded the devices I ticked the serial option in the BT manager and then reset my xda, when it restarted in the GPS manager I had a port called BT GPS Com7, tom tom now talks fine :D |
Darren Frequent Visitor
Posted: Tue Mar 08, 2005 8:47 am Post subject: |
And for the purposes of clarity, the fault here lay with the XDA and not TomTom or the GPS receiver.
I'm still not sure why you had to resort to using Bluetooth Tools as it should work without but if its working now that is all that matters _________________ Darren Griffin |
Posted: Tue Mar 08, 2005 11:12 am Post subject: |
You need the tools as the standard BT stack from Microsoft (on my m1000) doesnt allow you to change any settings, BT Tools allow you to setup com port 7 for the GPS.
Worked fine on my way into work this morning :D |
Posted: Tue Mar 08, 2005 12:38 pm Post subject: |
With the latest ROM update that's not the case, I had issues with the early builds on my XDAII but the later v1.72 update fixed them.
Not an issue any more as I installed the WM2003SE ROm with landscape support and it works like a dream _________________ Darren Griffin |
Posted: Tue Mar 08, 2005 6:58 pm Post subject: |
Orange are no longer doing any updates for the m1000 I'm stuck with rom 1.66, still now I have BT working I'm happy with it :D |
sysinfo Occasional Visitor
Posted: Tue Mar 29, 2005 7:24 pm Post subject: BT GPS |
Hi I had the same prob. You have to tell the Pda to connect to the gps over and above pairing. Charge the BTGPS fully and remove battery for at least 12 hours .
Regards
Bob |
Posted: Tue Mar 29, 2005 7:30 pm Post subject: |
scrw wrote: | Orange are no longer doing any updates for the m1000 I'm stuck with rom 1.66, still now I have BT working I'm happy with it :D |
It's a cinch to upgrade to the WM2003SE 2.02 Rom available over at [url=www.xda-developers.com]XDA-Developers. I'm running it on my XDAII (identical hardware to the m1000) and it's rock solid and gives OS Native Landscape support. _________________ Darren Griffin |
