Pocket GPS World :: View topic - ipaq 2210 and cf gps
Filler
PostPosted: Wed Mar 09, 2005 9:25 am    Post subject: ipaq 2210 and cf gps Reply with quote
Posted: Wed Mar 09, 2005 8:12 am Post subject: ipaq 2210 cf cards
does anyone know if there is a CF adaptor, that will allow me to fit the cf gps adaptor so that it sits on the back of the ipaq.
ie a z shape adaptor.
Nigel
Nigel
Blackberry Storm
iphone 3gs
Kenwood 5520bt with garmin built in
TT wired GPS - Rikaline Bluetooth 6030 GPS - CF307 CF card GPS - 512mb sd card - sprite full updated, and tt3 , 3.07. 256mb CF card - Win XP SP2 upgrad
PostPosted: Wed Mar 09, 2005 10:11 am    Post subject: Reply with quote
Not that I have heard of, is this because you have something in the SD slot that obstructs it?
Filler
PostPosted: Wed Mar 09, 2005 3:00 pm    Post subject: cf card Reply with quote
no it sticks out of the top, and is ungainly, i often think i'll snap it off
it wont fit in the car "fouls windscreen" so i use my tom tom corded one in the car.
:P :P :P
Nigel
Blackberry Storm
iphone 3gs
DavidW
PostPosted: Wed Mar 09, 2005 3:19 pm    Post subject: Reply with quote
It's arguable, then, that you bought the wrong CompactFlash GPS. The Haicom HI-303 series have an adjustable and foldable top section.
I'd be surprised if you broke your CompactFlash GPS - the cross section allows quite a bit of strength (unlike an SDIO GPS). Even if you could find the sort of gadget you were after, the resulting system would be very unwieldy IMHO.
MarkHewitt
PostPosted: Fri Mar 11, 2005 11:20 am    Post subject: Reply with quote
Same reason I got rid of my CF GPS, it fouled the windscreen when putting the ipaq in and out of the cradle, and restricted my visibility too.
Not to mention it causing it to crash (the software, not the car Smile ) every 5 minutes.
Filler
PostPosted: Fri Mar 11, 2005 5:30 pm    Post subject: cf gps Reply with quote
I use the wired serial in the car,
But i also have bluetooth which falls over every 10 minutes, which someone has suggested, is a problem with running everything on the sd card. I should by a 512mb CF card and try the bluetooth again.
I bought the CF for portable use, got it cheap on E-bay. works well just unweildly. maybee buy a new haicom instead.
Thanks for the info though
nigel
Nigel
Blackberry Storm
iphone 3gs
icsys
PostPosted: Sat Mar 12, 2005 1:16 am    Post subject: Reply with quote
I would definitely recommend using compact flash with your 2210. The SDIO drivers on it are said to be troublesome. As I have never used SD cards with it I can't actually confirm this.
What I can confirm is that I have not experienced any problems with Bluetooth nor had a bluetooth dropout using 128, 256 and now 1024 CF cards. Once a BT connection is established it is rock solid.
Ian.
iPAQ 2210 | Navman 4100 BT Receiver
Navman iCN 635
TomTom GO
Anquet OS mapping
22.051 (01 May 24)
