sunter18 Occasional Visitor
Posted: Sun Jan 23, 2005 4:08 pm Post subject: |
44, I use the trip planner on a daily basis in my job (i drive a non emergency ambulance dropping off & picking up patients from hospital) but i first have to work out the route order in which to input. would be useful if the Navman could work out the order route starting with the nearest.
45, have the route worked out so that the vehicle is facing the correct direction to drop off passenger on the nearside, if house number is recognised
46, this may be available, if so i have not worked out how to access, show the total route of the trip planner to show all drop off points are in the itinery( have had a couple of occasions where even tho address was inputed it was missed when on route) or show on screen next destination. |
Posted: Thu Jan 27, 2005 7:40 pm Post subject: |
ignore No.44 have had time to play today and found it to be present already. |
Posted: Thu Jan 27, 2005 7:42 pm Post subject: |
oops make that 46 not 44. Dam why can you not edit on here lmao |
chimera Occasional Visitor
Posted: Wed Feb 02, 2005 4:56 am Post subject: |
47a) when using POI - ability to search POI's byName (store name, street name, town/location name etc.) like google search. Currently, one has to navigate thru byCategory and byType. It's too time consuming to go trhu the category.
The search should be more flexible and more random. Currently, the pattern is matched one alphabet letter at a time in the order they are entered. Can I just enter "post" and get a listing of all POI occurences which contain "post" string, eg. Post Office ? I stumbled on this at one time because I didn't expect it to be under"AMENITIES" category.. And, how am I supposed to know this post office in my neighborhood for the last 10 years is called "ENICAL STATION", and that POST OFFICE isn't part of the name.
48) It'd be nice if the street name which Im about to enter/turn is flashing or blinking when I'm approaching the intersection.
49) Text -> Speech. Can the program read out loud the street name?
50) Why can't it just simple says "make a U turn" instead of the double left turns (left turn and then a left turn)?
51) Restaurant Type should have a subtype of "FastFood"
52) Ability to list and manage all "Avoid Areas". Some of these areas are only temporary because of construction. Also, the color of these marked areas should be bold and highlighted more. Red or orange is a better color choice. Current color is grey.
53) The POI icons need improvement for readability, eg. shopping centers, travel agencies. It's hard to understand what these icons really represent.
54) The street name anchor (a little red square) at the beginning or the end of the block, needs to be more bold. In 3D view, it's so hard to visually match the names to the streets. |
anglefire Regular Visitor
Joined: 27/05/2003 22:32:53 Posts: 114 Location: Solihull, West Midlands, United Kingdom
Posted: Wed Feb 02, 2005 9:29 pm Post subject: |
52) This is an addition to the one previously posted! Have permanent and temporary avoids - Often I want to avoid an area just the once! _________________ Mark
Website
The answer is 42. Now what is the question? |
rapido Occasional Visitor
Posted: Thu Feb 10, 2005 9:50 pm Post subject: |
53) The ability to use the software on your PC making it easier to plan routes etc.
Ken |
Posted: Thu Feb 10, 2005 10:47 pm Post subject: |
54) The ability to add maps to an SD card with the iCN plugged in too! _________________ Mark
Website
Posted: Thu Feb 10, 2005 10:51 pm Post subject: |
Duh! Scratch the last one, should have read:
54) The ability to add maps to an SD card without the iCN plugged in too! _________________ Mark
Website
dununda Occasional Visitor
Posted: Sat Feb 26, 2005 4:02 am Post subject: |
55) Ability to tap a location on a map and have pop menu choice "Center" that scrolls the map and places the tapped point bang in the center for accurate zooming in.
56) Setup > Maps: Option to "Select all" or "Unsect All". |
Simon1 Frequent Visitor
Posted: Sat Feb 26, 2005 10:48 am Post subject: |
dununda wrote: | 55) Ability to tap a location on a map and have pop menu choice "Center" that scrolls the map and places the tapped point bang in the center for accurate zooming in. |
If you tap the map so the cross-hair appears, the map will then zoom in on the centre of the cross hairs. |
Posted: Sun Feb 27, 2005 3:10 am Post subject: |
This does not work for me Simon1. If I tap on a map in SmartST3 on the Palm or PPC no cross hairs appear. If I hold the pen on the map I get the pop up menu only. Perhaps your version of SmartST behaves differently on another OS? There is cross hair button that appears at bottom right of the screen but tapping on that either centers a route or centers on a previously selected fatvourite. What I want is to be able to center and zoom straight in on any point I tap on the map. _________________ BT77 GPS
Palm T3
Navman SmartST v3.0 |
Posted: Sun Feb 27, 2005 12:10 pm Post subject: |
Aah - I'm using the icn510 and it must be different. |
SamOntario Occasional Visitor
Posted: Sat Mar 26, 2005 3:49 pm Post subject: |
57. After entering "destination" and then tap "go", show a simulation drive button with selectable speeds and showing preferred POI on the route to the detination b4 starting off the trip. |
breers Occasional Visitor
Posted: Sat Apr 09, 2005 7:22 pm Post subject: |
32- can the post code finder be upgraded to enable a full post code search and can my street be included - 65 Thorntree Gill Peterlee County Durham SR8 4SR - thought I would mention this as I have had no reply from teleatlas (reported this to teleatlas via a link on this forum) - (what happend to customer servie teleatlas?) |
BBB Regular Visitor
Posted: Mon Apr 11, 2005 6:29 pm Post subject: |
RE: 50
It does "Perform a U-turn when possible" - the left then left happened to me when I chose to continually ignore request to perform U-turn
55? - I'd be happy if it did what it said it would on the box
Oh the joys of being an early adopter? |
