Pocket GPS World :: View topic - Is my new Navman broken?
ebbsfleet_gooners
PostPosted: Thu Dec 30, 2004 12:15 pm    Post subject: Is my new Navman broken? Reply with quote
I was experimenting this morning with adding POI’s when I disconnected the usb cable I moved over to the window to enable it to recive a GPS signal which it did but now it does not load up any maps.
Tried resetting and checked that the map data is still on the SD card it gets a GPS signal but just says got to nearest road at the bottom of the screen
Have I broke it
Any thing I can try
Crying or Very sad Crying or Very sad
Jelster
PostPosted: Thu Dec 30, 2004 12:23 pm    Post subject: Reply with quote
Ah, I did that today as well.... I reloaded the base map and all seems fine now.
Completely lost in the world of GPS
Garmin Nuvi 760
ICN510 & Autocom - CBR900 RR3
ebbsfleet_gooners
PostPosted: Thu Dec 30, 2004 12:46 pm    Post subject: Reply with quote
Managed to get it back by un-ticking all the maps on the map on memory card screen then going back in and ticking all the maps
seems to be ok now.
wavesportkermit
PostPosted: Sat Jan 08, 2005 10:18 pm    Post subject: confused by memory cwrd screen Reply with quote
HI,
New to navman software, could you please explain what you mean by 'on the map on the "memory card screen" ~ (where is this screen - on the PC or icn?)
confused Sad
m62-to-hull
PostPosted: Mon Jan 10, 2005 2:35 pm    Post subject: Getting ya maps back .... Reply with quote
I've experienced similar map-loss problems ....shocked at first ...then irritated but now I know what to do.
I found that leaving the unit switched on, taking out my memory card & sliding it back in forced the unit to re-load whatever was on there. The map data returns each time.
The only peculiarities I've not solved are the speed cameras ...the data always loads BUT sometimes the icons aren't visible for one of the camera types. I find the icon recognition a bit hit & miss ...unless its my competence that's hit & miss, of course !
Tim Buxton
PostPosted: Mon Jan 10, 2005 2:47 pm    Post subject: Reply with quote
M62-to-Hull,
Have you installed the Service Pack for your iCN. This appears to have cured the invisible Custom POI phenomenon, at least for the PiN/PPC version. iCN users have reported the same....
Tim
m62-to-hull
PostPosted: Mon Jan 10, 2005 2:52 pm    Post subject: Reply with quote
Yes, I believe I did load the service pack ...dated 29 November I think it was. The ISN desktop does that, by check for updates -yes ?
Tim Buxton
PostPosted: Mon Jan 10, 2005 3:27 pm    Post subject: Reply with quote
Yes, with your iCN connected to said desktop, anyway. I don't have an iCN either, otherwise I'd be able to tell you the software version to expect.
Oh well, it was worth a try. Mind you, if you connect your iCN to your PC and look for updates again using the iCN Desktop, it'll tell you if one is available. If two or three of the numbers in the lefthand column show 1 as opposed to 0 then it's definitely updated.
Tim
Icelus
PostPosted: Mon Jan 10, 2005 4:44 pm    Post subject: Reply with quote
Here is the information on the software versions for the iCN510:
Un updated iCN to Service Pack 1 shows:
iCN510 Version: v3.01.1008,
English: v3.0.1000,
Built on: 2004-11-22 12:38:48(B),
Core: T-core-v1_16_0039 2004/11/05-14:41:16.
Non updated iCN shows:
ICN510 Version: v3.00.0027,
English: v3.01.00003
Built on: 2004-09-02 12:44:12(B),
Core: T-core-v1_16_0029 2004/09/02-12:44:16.
You can download Sp1 here:
http://www.navmansupport.com/smartst_pro/SmartST_Pro/NavmanUpdates.html
m62-to-hull
PostPosted: Mon Jan 10, 2005 6:14 pm    Post subject: Navman update Reply with quote
Heay, thanks. I thought I'd successfully updated my 510 but with those build numbers and dates, I could see that I hadn't managed. Done it and can already see some of the improvements. I hope map data updates are as easy ...yeah, right !
