Pocket GPS World :: View topic - Help! Toshiba e750/Earthmate with USB<->Ser cable
tbfisk
PostPosted: Thu Jan 06, 2005 10:07 pm    Post subject: Help! Toshiba e750/Earthmate with USB<->Ser cable Reply with quote
I have the DeLorme Earthmate running (err...well…sometimes…) with a USB<->Serial cable on a Toshiba e750 with the Prolific PL-2303 driver. The problem that I have is that about 95% of the time, when connecting the USB<->Serial cable to the e750 the error message
USB OVER CURRECT DECTECT
USB device is turned off. Please
Disconnect USB device.
I have tried everything I know of to try to figure out why this is coming up…from soft reboots to a total device reset. Usually I can get everything working after a total device reset…but only for a while. If a soft reboot is done, then most likely I will end up with the error message again.
Have you heard of this? Any ideas?
Thanks!
Tom
lbendlin
PostPosted: Fri Jan 07, 2005 12:00 am    Post subject: Reply with quote
I think the message says Over-Current. Get a GPS receiver that consumes less power.
Lutz
TomTom/TeleAtlas NAVTEQ
tbfisk
PostPosted: Fri Jan 07, 2005 12:34 am    Post subject: Reply with quote
Yes...a typo on my part. Over Current. I am using a powered USB<->Serial cable from Supply.Net (http://www.thesupplynet.com/searchresults.cfm?mySearch=product&prodName=210) that supposedly powers the GPS device rather than the e750.
So you are saying that the GPS is not getting enough power?
lbendlin
PostPosted: Fri Jan 07, 2005 12:47 am    Post subject: Reply with quote
yes, the GPS (and the USB>Serial converter) draw more current than the Toshiba can deliver
Lutz
Pc-Mobile
PostPosted: Fri Jan 07, 2005 4:16 pm    Post subject: Reply with quote
The cable should power BOTH the PDA and GPS.
The over-current message may pop up occasionally in this set up (USB>serial converter).
Does it come up with or without external power (from cigar lighter)?
If it comes up consistantly with external power connected, you may have a defective cable.
Pc-Mobile
http://pc-mobile.net/gps.htm
22.044 (24 Apr 24)
