Pocket GPS World :: View topic - Using Fugawl uk maps and CF GPS
DavidJ26
PostPosted: Sat Jan 01, 2005 5:04 pm    Post subject: Using Fugawl uk maps and CF GPS Reply with quote
I have a Dell Axim 5 and Tom Tom Navigator 3 as well as a CF GPS all this works well but I'm trying to use Fugawi uk didital maps for walking and although I can download maps I can't get the GPS to work. Any suggestion? Hope you can help. Sad
alix776
PostPosted: Sat Jan 01, 2005 5:08 pm    Post subject: Reply with quote
youll need to down load gps 2.07 for the downloads area as all versions after this lock the serial port theres quite a few posts on this if you serch through the forums youll find the information youll need look through the beginners and tomtom forums
device Lumia 950 xl
DavidW
PostPosted: Sat Jan 01, 2005 8:59 pm    Post subject: Reply with quote
Alix gives one solution - but if you're going to install another version of TomTom GPS, make sure you remove your current version of TomTom GPS completely first.
You may find that a single remove of TomTom GPS is enough, which will unhook any changes it's made to your Bluetooth stack (which is what's causing the problem).
To remove TomTom GPS, turn off Bluetooth and soft reset.
Go to Start Menu, Settings, System tab, Remove Programs. Tap on TomTom ~ GPS, tap Remove. You will probably be asked to press OK for a mandatory soft reset.
At this point, Fugawi will probably work.
If you want to remove TomTom GPS completely to install a different version, repeat the removal instructions until TomTom ~ GPS has disappeared from your Remove Programs list.
Some people report that the latest version of TomTom GPS, 3.07 (which is available from the TomTom web site), is less troublesome than older versions when it comes to allowing other applications to use your Bluetooth GPS. That's one version you could try if you decide to try another version; the other is 2.07 as Alix mentioned. As I said, whatever you do, make sure one version is completely removed before trying another.
If different versions of TomTom GPS and/or a single remove of your existing version of TomTom GPS doesn't solve the problem (one or the other usually solves the problem on an iPAQ, but may not on an Axim) post again.
22.053 (15 May 24)
