Pocket GPS World :: View topic - Mitac 168 sound fix
Mitac 168 sound fix
gripp
PostPosted: Mon Dec 06, 2004 4:45 pm    Post subject: Mitac 168 sound fix Reply with quote
To all Mitac 168 owners...
I have just successfully applied the updated wavedev.dll file to my Mitac 168 and it has certainly fixed the bad sound which was clearly audible during the first 2 or 3 seconds of recording/playback. The fix is available at the Mitac website: http://www.mio-tech.be/downloads/default.asp
I remember reading a while back that someone on here had had a bad experience applying this fix, so full backups are a wise precaution before applying it.
All I can say is that it worked for me.
Nokia E65 & TT Nav6
bernieeccles
PostPosted: Tue Dec 07, 2004 7:19 pm    Post subject: Reply with quote
How did you do it ?
I have downloaded the file and extracted it and end up with two files.I copied them to my storage card,but then what ?What application uses runs these files ?
Confused !
gripp
PostPosted: Wed Dec 08, 2004 10:03 am    Post subject: Reply with quote
There are two CAB files, one for the Mio168 and one for the Mio336 so ensure that you've downloaded the correct one (file size zipped = 30Mb for Mitac 168).
Copy the correct CAB file to your SD card and then double click on the CAB file from within File Explorer which will in effect run the extraction process and load the patch.
It then shows on the list of installed programs meaning that you can fall back to the original file should you wish.
Nokia E65 & TT Nav6
Diplo
PostPosted: Wed Dec 08, 2004 2:23 pm    Post subject: Reply with quote
Does this work with the Aldi Medion 95000, which is based around the Mio 168?
gripp
PostPosted: Thu Dec 09, 2004 12:08 am    Post subject: Reply with quote
Sorry, I don't know the answer to that question.
Nokia E65 & TT Nav6
bernieeccles
PostPosted: Thu Dec 09, 2004 8:35 pm    Post subject: Reply with quote
I have copied the file after extraction and before extraction to my storage card but when I click on it/them all I get is a message saying that I need to run a suitable application .
What am I doing wrong ?
gripp
PostPosted: Fri Dec 10, 2004 12:20 am    Post subject: Reply with quote
Do you also have a Mitac168?
If this doesn't work then I assume you've either got the wrong file or it's not compatible with your PDA.
Nokia E65 & TT Nav6
bernieeccles
PostPosted: Sat Dec 11, 2004 3:59 pm    Post subject: Reply with quote
Well to be fair it is the medion 95000,but it is a clone of the mitac,so I can't see why it would not work !
gripp
PostPosted: Sat Dec 11, 2004 9:26 pm    Post subject: Reply with quote
Why not cantact Medion and ask them?
Nokia E65 & TT Nav6
bernieeccles
PostPosted: Mon Dec 13, 2004 12:03 am    Post subject: Reply with quote
I have this irrational fear of spending hours with a telephone stuck to my ear 8O
