Pocket GPS World :: View topic - Fall Back (Tomtom Go Clock)
Goto page 1, 2, 3  Next
BoxsterBoy
PostPosted: Mon Nov 01, 2004 9:22 pm    Post subject: Fall Back (Tomtom Go Clock) Reply with quote
After setting all the clocks in the house and cars etc.. I would have presumed tomtom go would have beaten me to it. Not so. Going to set clock and 'sync' option and the time goes one hour ahead of what it should be eg GMT+1. Given that Tomtom knows which country I am in I would have thought it possible to work out the proper time (especially given the fact that UTC from the sats is correct.
I have tried using both 4.40 and the 4.42 update to no avail. Had to do a manual clock set to correct.
Maybe someone has figured it out or I have something else to e-mail Tomtom about?
sgould
PostPosted: Mon Nov 01, 2004 10:10 pm    Post subject: Reply with quote
I noticed that today as well. Most surprised.
ZZBeard
PostPosted: Tue Nov 02, 2004 12:04 am    Post subject: Time Zone setting Reply with quote
I am trying to remember if I/we was/were given the option of setting to a time zone, or a DST option when first powering the TTG up...
tonyfinn
PostPosted: Tue Nov 02, 2004 10:05 am    Post subject: Reply with quote
no, there isn't a time zone option. I can't see it being a problem to incorporate this feature though.
jdatkinson
PostPosted: Tue Nov 02, 2004 10:19 am    Post subject: Reply with quote
Noticed the same thing with 4.42 yesterday. It's easy enough to knock the clock back one hour but it does appear to be a minor glitch. Worth emailing TomTom, I guess. If they take on board all of things that the users of this forum have spotted the next big software update should be a corker!
stix
PostPosted: Tue Nov 02, 2004 2:22 pm    Post subject: Reply with quote
I haven't checked, but I don't think TTG has a date stored anywhere... this is also necessary if you want him to work the time out himself, as well as some table defining when daylight saving is applicable.
PostPosted: Tue Nov 02, 2004 3:10 pm    Post subject: Reply with quote
The GO will always set the time to UTC (what it gets from the satellite) and you will then have to adjust the hours back to your time zone. One wonders if TomTom have ever tested that feature outside of the GMT time zone.. I thought the Netherlands are GMT+1?
Sniff
PostPosted: Tue Nov 02, 2004 4:15 pm    Post subject: Reply with quote
It works the same outside the GMT timezone (I'm in Germany). The TTG sync feature sets the clock to UTC as per the satellites. But is it really such a big deal to flip it on one hour?
nej
PostPosted: Tue Nov 02, 2004 5:04 pm    Post subject: Reply with quote
Technically speaking (i.e being REALLY picky Wink ) the GPS receiver receives GPS time, which is actually 13 seconds ahead of UTC time (due to 13 "leap-seconds" being added since GPS time began in 1980.
PostPosted: Tue Nov 02, 2004 5:11 pm    Post subject: Reply with quote
Who says it's one hour? For me it's six hours Confused
Sniff
PostPosted: Tue Nov 02, 2004 5:31 pm    Post subject: Reply with quote
OK then, 6 hours in your case! :P
But seeing as I bought this thing as a GPS unit (which it does pretty well) and not an alarm clock, I'm not too fussed about it. Let's be honest, it only needs the clock setting for ETA, otherwise it has no need of it...
spacerunner
PostPosted: Tue Nov 02, 2004 10:05 pm    Post subject: Reply with quote
Just checked my time om TTG and its exactly right, well matches the PC clock.
spacerunner
PostPosted: Tue Nov 02, 2004 10:06 pm    Post subject: Reply with quote
The forum closk is way out tho'... :P
PostPosted: Tue Nov 02, 2004 10:20 pm    Post subject: Reply with quote
You will have to adjust your profile - Summer time has ended
jdatkinson
PostPosted: Thu Nov 04, 2004 10:00 am    Post subject: Reply with quote
So they've probably just set it to default to central european time rather than this being a bug. It's quick enough to roll the hours back on screen so it's not really a bug after all, is it?
Page 1 of 3
