Pocket GPS World :: View topic - Problem with 5.0.1.22 patch and 256Mb SD card
KenS
PostPosted: Sun Oct 31, 2004 9:42 pm    Post subject: Problem with 5.0.1.22 patch and 256Mb SD card Reply with quote
I have been unable to install the 5.0.1.22 patch. The installer keeps calculating the available space on my SD card as -6.9Mb when there is well over 130Mb free. This is at the point when the maps are prepared for download to the PPC.
Has anyone else had this problem and been able to work around it?
--Ken
HP iPAQ h2210 ROM 1.10.07 ENG
Windows CE 4.20
Sandisk Ultra II SD 512Mb
Haicom 303MMF and BT-401 slipper
Copilot Live 6.0.0.68
lexuscol
PostPosted: Sun Oct 31, 2004 10:08 pm    Post subject: Reply with quote
See if you apply the patch manually by using active sync, follow the instructions on alk site for install to pocket pc only. this way worked for me fine
Col
KenS
PostPosted: Sun Oct 31, 2004 10:55 pm    Post subject: Reply with quote
Thanks, Col
Did that and it worked
--Ken
Windows CE 4.20
MDRedwood
PostPosted: Mon Nov 01, 2004 6:42 pm    Post subject: Reply with quote
I had exactly the same problem (with almost an identical set-up to you) and solved it by using a USB card reader. It was much quicker that way.
Regards
Mike
22.052 (08 May 24)
