Pocket GPS World :: View topic - hgv satnav
hgv satnav
cocacola186
PostPosted: Wed May 10, 2023 8:21 pm    Post subject: hgv satnav Reply with quote
i am looking at getting a hgv satnav it must be able to get the pgpsw speedcam database on it and other custom poi. what do you reccomend pls
PostPosted: Thu May 11, 2023 4:59 am    Post subject: Reply with quote
Has to be a Garmin
Satnav:
Car Average MPG :
PostPosted: Thu May 11, 2023 11:12 am    Post subject: Reply with quote
Yep - definitely a Garmin. I know they do specialist HGV ones where you can input your width/height etc and it'll give you suitable routes (they're more expensive than car satnav's due to the extra data needed in the mapping)
Garmin are also one of the few remaining manufacturers that haven't blocked users from adding their own POIs and Speed Camera data etc.
Garmin's Truck range is here: https://www.garmin.com/en-GB/c/automotive/semi-truck-gps-navigation/
cocacola186
PostPosted: Thu May 11, 2023 7:10 pm    Post subject: Reply with quote
thanks for that info much appreciated so i will be able to add the pgpsw speedcamera warnings on to the dezl lgv610 model.?
PostPosted: Fri May 12, 2023 3:56 am    Post subject: Reply with quote
We cannot be 100% sure but I think we can be 99% sure.
I've never yet come across any Garmin SatNav that hasn't allowed the PGPSW database to be loaded and work as intended.
Just follow the 'spoon feed' tutorial or use my CSV to GPX Converter if you want more control over alerts timings.
Both are stickies in the Garmin section.
Satnav:
Car Average MPG :
PostPosted: Fri May 12, 2023 9:26 am    Post subject: Reply with quote
I've found the manual online for the Dezl LGV610 and you can add Custom POIs using POILoader and these can contain speed alerts. I.e. - yes, it is compatible.
cocacola186
PostPosted: Sat May 13, 2023 8:43 am    Post subject: Reply with quote
thankyou for your help.
22.051 (01 May 24)
