Newsletter
Pocket GPS World :: View topic - Drivesmart 55 POI now showing
T5YOB
PostPosted: Thu Jul 28, 2022 5:29 pm    Post subject: Drivesmart 55 POI now showing Reply with quote
Wondering if anyone could help with why my points of interest I downloaded off this site won't show on my Drivesmart 55 anymore? You know like the little McDonald's, KFC symbols. They used to work fine and the POI file with them all on is still on my nav.
PostPosted: Fri Jul 29, 2022 5:25 am    Post subject: Reply with quote
I've never used personal POI'S but maybe worth going through all settings.
Satnav:
PostPosted: Fri Jul 29, 2022 7:58 am    Post subject: Reply with quote
Not showing where? Difficult to answer without a bit more detail
T5YOB
PostPosted: Fri Jul 29, 2022 5:19 pm    Post subject: Reply with quote
On the errr map on the Sat Nav.
And all POI settings are turned on, nothing has been changed. Wonder if it's from a software update that's stopped them working for what ever reason. All the Speed Camera's icons show fine from the database here.
PostPosted: Sat Jul 30, 2022 4:38 am    Post subject: Reply with quote
If you just load the map and scroll around, the speed camera POI's don't show until they become in range while driving.
Maybe other POI'S are the same.
Can you use/find the POI's to navigate to ?
Satnav:
PostPosted: Sat Jul 30, 2022 6:33 am    Post subject: Reply with quote
Well it could have been the map, the POI list, the Up ahead feature ....
I have POIs turned off otherwise they clutter up the map. Check that Settings, Map and vehicles, Map layers, Up ahead is checked.
If it is and you've noticed this change after a software update then a master reset should cure it. This assumes they do actually show when you do a Where to, Categories, Custom POIs?
20.033 (17 Aug 22)
