Pocket GPS World :: View topic - Garmin DriveSmart 65 MT-D Verbal speed camera warning.
Goto page Previous  1, 2
INTRANET
PostPosted: Wed Oct 06, 2021 1:30 pm    Post subject: Reply with quote
Strange warning on motorway. Unverified speed camera 40mph ahead. From London to Kent shortly before of Medway viaduct M2.
I get warning about here. Photo is an example.
PostPosted: Wed Oct 06, 2021 2:36 pm    Post subject: Reply with quote
Very difficult to know where that is.
Can you get a Lat/Long rough idea so we can look it up.
The yellow 'We Need You' icon on the right panel will display a map and will help to identify a closer location.
INTRANET
PostPosted: Wed Oct 06, 2021 2:49 pm    Post subject: Reply with quote
Unfortunately I can't give Lon. Lat. I'm in home now. But there isn't any speed sign to drive on 40. So this may be dangerous for someone who slow down on right line to 40. Can I get from my history route info about speed camera?
Update: Interesting: https://www.speedcamerasuk.com/database/SEK/sek039.htm
dales
PostPosted: Wed Oct 06, 2021 4:01 pm    Post subject: Reply with quote
It's this one
pMOBILE:199644@40
Dales.
PostPosted: Wed Oct 06, 2021 4:48 pm    Post subject: Reply with quote
Thanks D
Saves me searching.
I don't load pMobiles, personal choice, I treat every road as if there is a Kojak with a Kodak round every corner.
I did load them ages ago and I got 8 back to back warnings at an overpass because I was a few mph over the limit for both roads so I got the main warning and an overspeed for 4 pMobiles.
The advantage was the wife kept getting interrupted Very Happy
PostPosted: Wed Oct 06, 2021 5:58 pm    Post subject: Reply with quote
On that page it's logged as a Gatso! Confused
INTRANET
PostPosted: Thu Oct 07, 2021 1:26 pm    Post subject: Reply with quote
Ok, strange more spotted cameras (x3) on M20 to Ashford. PGWC says average speedcamera 50mph on motorway but no signs which says 50. For the moment I turned off. Let see how Garmin Speed camera system does work.
I asked my gf to turn on phone nav app.
PostPosted: Thu Oct 07, 2021 3:03 pm    Post subject: Reply with quote
I would suggest using POILoader to first remove any and all databases then reinstall with the latest.
Wouldn't be the first time we've seen multiple databases with the old one totally obsolete.
INTRANET
PostPosted: Thu Oct 07, 2021 3:37 pm    Post subject: Reply with quote
If I reset to factory settings will it remove custom POI/Speed cameras? I don't know how to remove POI using POILoader.
PostPosted: Thu Oct 07, 2021 4:12 pm    Post subject: Reply with quote
No, maps and POIs aren't affected by a master reset. You can just go into the POI folder and delete them directly if you prefer.
If you do that though check there aren't any .gpi files elsewhere as although they should all be in the POI folder a Garmin will hoover them up even if they aren't
PostPosted: Thu Oct 07, 2021 4:19 pm    Post subject: Reply with quote
POILoader has 2 options - add or remove - run POILoader and all will become clear
INTRANET
PostPosted: Thu Oct 07, 2021 6:48 pm    Post subject: Reply with quote
Thanks PIO's removed via POIloader.
PostPosted: Fri Oct 08, 2021 4:35 am    Post subject: Reply with quote
Good
Now perform the database load and you know you are running just the latest database.
If the issue persists then report back.
Page 2 of 2
